Infinite lines
All  1-4  5-10
4032.5 In reply to 4032.3
Hi Marc,
> I was imagining a continuous line that would be
> selectable like other objects, that could be moved
> around as your project evolve.
One problem with trying to treat an infinite line as if it was the same as a regular object is that it can't really be used for input into all the commands as regular curve objects.
For example it would not work to try and extrude an infinite line, or revolve it, etc...
There's some potential for confusion when something looks as if it is a regular object and selects and moves like one, but then when you try to actually use it in other ways the same as other objects it then suddenly stops behaving like the other objects that it appears similar to.
In a 2D only type CAD system I guess you would not have that same kind of problem.
4032.6 In reply to 4032.5
It make sense, it could be confusing this way...
Well, it was just a thought.
> I simply set up a style with a pale color and use that
> for construction or grid lines and can hide them or make
> them visible for reference.
Hi Eric, yes this what I do also!
Marc
4032.7 In reply to 4032.6
I think construction lines are selectable and movable
4032.8 In reply to 4032.7
Yes just click on the little thumbnail that appears at each helpers line release ;)
you can move rotate re orient Divide and project !
4032.9 In reply to 4032.7
Hi Burr,
Yeah they are if you use one of those script methods to make one that stays around after the current command exits.
But it's kind of hacky - they don't have highlights or show in selected colors even though they can be dragged around. It's not really a fully finished off area.
4032.10
Solidworks allows infinite lines. They can be construction lines or real lines. If they are left as real lines, SW ignores them when using the sketch, say, for extruding. This is confusing so I always convert them to construction lines.
Show messages: All  1-4  5-10
