Hotkey for "Show View Controls"?
4026.1
Hi
I'm just wondering, is there a command I can use to enable/disable the View Controls?
(the option I'm referring to is located under Options -> View -> Show view controls)
I'd like to be able to enable and disable this (either toggle, or by holding a key down) via a shortcut key.
Thanks!
-EDIT-
Oh, and I'd also like to make my toggle grid shortcut toggle the grid axes as well as the grid.
Currently:
script:moi.grid.display = !moi.grid.display;
(but I'm not sure if there's a command for the grid axes?)
EDITED: 4 Feb 2011 by NIGHTCABBAGE
4026.2 In reply to 4026.1
Hi NightCabbage, for toggling the view controls on or off with a keyboard shortcut, paste in the following as the command part of the shortcut key:
script: /* Toggle view controls */ moi.view.showViewControls = !moi.view.showViewControls;
Note that when you toggle them on they won't actually show until you move the mouse again.
For toggling both the grid axes and the full grid together with one key, use this:
script: /* Toggle grid and axis lines */ moi.grid.display = !moi.grid.display; moi.grid.showXYAxes = moi.grid.display;
4026.3
Perfect on both counts, thank you Michael! <3
