problem with fillet and shell
 1-9  10-29  30-31
4023.10 In reply to 4023.7
Hi Jurgen,
> I was able to apply a .2 Fillet to your 'KleinTeil clipped',
> but I was not able to separate the 'desired object' from
> the 'border' cut away, i.e. I could not DELETE the 'border'.
Hmm, yeah at some point it was working but not after I saved and reloaded the model.
When you get a fillet that has this odd border thing in it, it means that the filleter was able to generate fillet surfaces but it ran into some kind of error when trying to trim the main object when cutting it with the fillet surfaces. It returns the generated surfaces in this case so that you may have a chance to do some work on things to salvage them.
It seems to be having some additional difficulty in this area of the model here:
It's actually not so good for filleting when both sides of the edge are curved surfaces to have edges join to a common point like that, because fillets work by a kind of surface offset and that means that one fillet goes like this:
And the other fillet goes like this:
So that leaves a kind of gap area between the fillets that the filleter has to deal with filling in, and the filleting engine seems to have some difficulty handling areas like that.
If you zoom in on this area of the fillet surfaces you will see a kind of problem area:
It's possible that if that connection piece is repaired (like maybe just deleted and a loft put in between the ends of the other longer fillet pieces), that it could then be used to trim the main object succesfully with the Trim command to incorporate the fillet into the main object.
4023.11 In reply to 4023.10
Hi Jurgen,
I've attached a version here that has a 0.2 radius fillet applied to that "KleinTeil clipped" model version.
I had to do some repair work on that one area I showed above (also the fillet piece from above needed to be untrimmed, the filleter had incorrectly trimmed the fillet back a little bit too much making it stop short of the surface edge), and then trim the various surfaces of the main body to the fillet edges and then join all the pieces up to a solid again.
To make this version shelled, you'll actually want to go back to the original unclipped model, and use the Construct > Offset command with the "Flip" option checked to create a sort of inner core piece. Then take this filleted model and use the boolean difference command and select that inner core as the cutting object, and that should result in a hollowed out cavity within this shape to save on materials. Use window selection (where you click in an empty area and then hold down and drag to make a selection rectangle) to select the inner piece in the boolean difference command, since it is not easy to click on it since it is contained within the main piece.
Hope this helps!
If you don't like the clipped areas in this version, your best bet may be to delete those faces in this model version and construct some new surfaces in those local areas.
4023.12 In reply to 4023.8
Thank you for your explanations. I understand FILLETing now much better.
I was able to SHELL KleinTeil.3dm too and have submitted the shell to the 3D-Printing company.
I will receive the result in about two weeks and could show it here, if this would be of interest.
>for removing internal volumes, you can just model some rough shapes and put them inside the model and use boolean difference to make them cavities within the main shape -
I will follow this very helpful suggestion, which meets my objective of reducing 3D-Printing costs :-)))
thanks & regards
Jurgen
Seems you must round the pikes for have a more hamonious form :)
4023.14 In reply to 4023.10
Thank you for the explanations and the repair work.
I always wondered why the straight lines on the model are there, as the model has essentially only two continuous surfaces.
I there any way to remove those lines? This would probably reduce the repair work.
thanks & regards
Jurgen
4023.15 In reply to 4023.14
Hi Jurgen,
> surfaces.
Those lines are the edges between the different surface pieces that make up the model. Even though your overall form has a continuous surface, your particular model construction is made up of several surfaces that are joined together at shared edges.
Usually that kind of structure is the result of the segments in your original curve structure coming through. For example if you have a curve that is made up of 2 segments joined together, when you extrude it you will then end up with 2 surfaces joined together following the same segment structure as the original curve.
There isn't an easy way in MoI to remove them after you've already got it all constructed - it would require merging the separate surfaces together into a larger single surface. I do plan on adding in a tool to MoI in the future that will do that.
You can avoid those being created in the first place if you make your original curves be long single pieces instead of constructed of multiple joined segments. The Rebuild command can be a good way to build a new single segment curve out of a multi-segment one:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
4023.16 In reply to 4023.13
thank you for your suggestion.
I have done this already (see the file 'Kleines Teil rounded', which I originally attached).
See the replies concerning this version.
regards
Jurgen
4023.17 In reply to 4023.15
Hi Micheal,
I am looking forward to get this tool.
Until then I'm happy with what I can achieve following your suggestions.
I will try the REBUILD command when creating my next masterpiece ;-)
thanks again
Jurgen
4023.18 In reply to 4023.16
Ah, sorry, i had only loaded the normal file :)
4023.19 In reply to 4023.15
I have applied a 100 points Rebuild to the Curve around this Solid.
How could I create a Solid with this Curve (like the original Solid)?
How could I create surfaces with this curve (like the two surfaces of the original solid)?
thanks & regards
Jurgen
4023.20 In reply to 4023.19
Hi Jurgen,
Right now it looks like you're trying to think of following the 3D curve that is swooping around in 3D space.
Instead try to focus on the 2D profile aspects of the shape and try to figure out how you would create some 2D curves to construct it.
So for example note that these side surfaces are straight in one direction:
That kind of straightness usually implies an extruded surface, so to build something like that, get a flat profile curve drawn in one of the 2D Top/Front/Right views that looks like this:
Then you can Extrude this to build the base underlying shape, like this:
Now you want to remove some of that material, create some side profiles something like this:
Now you can use a boolean command to slice the extrusion with that side profile, in this case use the Boolean Intersection command - that will only keep the area from the extrusion that is also inside of that 2D profile curve, like this:
It's also possible to run boolean intersection just directly on the 2 planar profile curves, it will automatically do the extrusions for you, see the help file topic for an example:
http://moi3d.com/2.0/docs/moi_command_reference7.htm#booleanintersection
But basically you can get stuck pretty easily if you're trying to think about how to create something following contours that are swooping around in 3D - instead of thinking like that, try to imagine some larger uninterrupted forms of the object, and build those as some larger initially more simple extended piece (like the extrusion above), and then get your final shape by cutting that object with other profiles to remove material from it.
Basically try to ignore things that look like cut out areas for the first stage of figuring out how to build the basic shape - build a bigger piece first and then make the cut out areas happen by slicing that shape, rather than trying to do something like try to sweep directly along complex 3D swooping boundaries or things like that.
4023.21 In reply to 4023.11
you wrote: "Use window selection (where you click in an empty area and then hold down and drag to make a selection rectangle) to select the inner piece in the boolean difference command, since it is not easy to click on it since it is contained within the main piece."
Unfortunately I was not able to select the inner piece using window select (covering the entire object with the selection window).
Could you please explain more detailled how to select the inner piece?
thanks & regards
Jurgen
4023.22 In reply to 4023.21
Hi Jurgen,
Please check out these previous posts for some animations and additional descriptions:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1810.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=3324.4
But basically the 2 main things are that you'll want to do the window select starting on the left and dragging towards the right (the left-to-right direction will make a selection box that will only select things entirely inside the box), and normally to do a window select you need to do the initial mouse down in an empty area of the screen - if there is no empty area easily available then hold down both the shift + ctrl keys before clicking which will force a window selection and avoid doing an object drag which is what would normally happen when you click and drag the mouse on top of an object.
4023.23 In reply to 4023.22
Thank you for the detailled explanation.
I was now able to select the inner piece and perform the boolean difference.
Unfortunately the result of my first try was not a 'clean' Shell.
But the result of my second try (with the original Solid) was a 'clean' Shell, after:
1. Separating the Solid obtaining 10 Surfaces
2. Joining the 3 Surfaces obtaining Surface A
3. Joining the other 7 Surfaces obtaining Surface B
4. Joining the Surfaces A an B obtaing a/the Solid
5. Offsetting (as you suggested)
6. Boolean Differencing (as you suggested)
Thank you very much again
Jurgen
4023.24 In reply to 4023.23
a little image of the result will be cool :)
4023.25 In reply to 4023.20
I completely agree with you.
My original solid was built the way you suggest, using Boolian operations to cut this solid out of a cube.
Only after running into problems with Shell and/or Fillet I was 'crying' for help.
But now my problem has been solved by following your explanations/suggestions: I was able to produce a 'clean' shell.
Thanks & regards
Jurgen
p.s. your 'realtime' replies are 'breathtaking'.
The next time I will probably get an answer before I hit "Post" ;-)
Thank you again for the excellent support you provide!!
4023.26 In reply to 4023.25
Hi Jurgen, you're welcome, and I'm glad you have a solution now!
4023.27 In reply to 4023.24
Please find attached the picture of the object discussed (rouge) and a picture of another object (white).
The white object is a 3D-printed Shell.
3D-printing Shells instead of solids saves material/money.
I am currently in Cannes.
If you are interested we could meet and exchange ideas/experiences.
regards/Jurgen
Size: 213.2 KB, Downloaded: 46 times, Dimensions: 2066x1550px
Size: 81.9 KB, Downloaded: 34 times, Dimensions: 1440x810px
cool sculpture :)
Cannes movie festival is alas closed ;)
4023.29 In reply to 4023.27
Hi Jurgen,
Have you done any work with modeling in support structure, like ribs, so you can produce large pieces?
Chris
Show messages:  1-9  10-29  30-31
