Shortcut keys problem V2
All  1-3  4-6
4021.4 In reply to 4021.3
Ahhh - I think the problem is that I am using a wacom tablet (intuos 4 PTK-640)...
When i just park the pen, and use only a mouse, then everything is fine. - I guess its is some sort of incompatibility within the wacom software...
cheers
rabbit
4021.5 In reply to 4021.4
Hi rabbit, hmmm yeah it sounds like wacom is doing something a bit different than the regular mouse that messes up those inputs.
At some point in MoI v3 I will likely be rewriting the shortcut key editor to actually work more like you had expected initially (where you will push the actual shortcut key itself to define which one you want to set), and a different editor structure will probably avoid this kind of inline editing problem because it will probably pop up a little dialog that says "type the key you want to assign" or something like that rather than being an inline edit control.
But I guess until then you've found a workaround of using the regular mouse to adjust those settings.
4021.6
Hello,
Do you have your regular function keys set or the secondary FN set engaged?
Show messages: All  1-3  4-6
