Surface fitting?
All  1-5  6-16
4013.6 In reply to 4013.4
Hi Michael, thanks for the comments.
I just downloaded the demo version of MoI which I probably should have done before my original post.
One advantage we have on this project is that we don't need to exactly reverse engineer the original design. We just need to capture it's essence. My mesh model I created is not exactly like the original prototype, and the prototype isn't exactly like the artist's 3 view (not to mention the artist's top, side and front dimensions don't exactly all match up either.) So there is some flexibility in the final result.
This is an RC scale aircraft (7-8 foot wing span) so the only major constraint is that we need the *exact* airfoil contour where the wings plug in. I have this contour as a series of X, Y data points. Is there a way to import a set of X, Y points into MoI and build a curve that passes through those points smoothly and exactly? There's about 60 data pairs, so it would be pretty tedious to plunk these in manually.
In my own little program that generated the mesh model of our design I just loaded in the X, Y points and built a cubic spline out of them. Can I create a curve in MoI from some external set of coordinates?
After playing with MoI for 10 minutes, I think that if I could import the exact airfoil contour somehow ... then I could mess around with the other curves and build the rest of the shape by dragging the control points around interactively. Once I had the airfoil locked in, I could probably spend 10 minutes on all the other parts and be awfully close to final result.
Is it possible to import a set of curve coordinates from some external data file?
Curt.
4013.7 In reply to 4013.6
Hi Curt,
There is a plug-in that you can download and copy to MoI's commands folder which will then make a new command called ImportPointFile available which can do that, see here:
http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile
4013.8 In reply to 4013.6
Hi Curt,
A conic curve is based off of a parabala type curve, so yes a cone is involved, though a conic curve is a type of analytical curve..
Conic curves and RHO values were used to design "airfoils"..... FOr a wing, you could have your "exacting measurements".
And as Michael said, I wouldnt want to try to reverse it, though from what I saw in your link, you should be just creating this stuff in MoI, from the start!
4013.9 In reply to 4013.8
Hey guys thanks for all the help. Using the ImportPointFile extension, I was able to import the slice boundaries I generated externally from my script as curves in MoI. Then I was able to generate a quite nice "Network" surface from them. Now I get to send it up stream so hopefully it doesn't come back for more tweaks. :-) Wow, MoI is a very cool and intuitive program ... really impressed with it.
4013.10
Ah yes, another bitten by the MoI bug...welcome Curt :)
4013.11 In reply to 4013.10
""""""""""Ah yes, another bitten by the #########MoI bug###############...welcome Curt :)"""""""""""""""""""
Sacrileges!!!!!!!!!!!!!!!!!!!!
4013.12 In reply to 4013.11
lol.........not that type of bug Burr!
4013.13 In reply to 4013.9
Hi Curt,
Can you make a scren shot and share it with us on what you have done with MoI and import points ?
4013.14 In reply to 4013.13
Here's a quick screen shot. I have to apologize ... I'm normally a Linux user and I can't remember the magic combination of keystrokes to grab a screenshot on windows. Could probably google it in 10 seconds, but it only took 5 seconds to whip out my cell phone ... :-)
Size: 1.7 MB, Downloaded: 108 times, Dimensions: 2560x1920px
4013.15 In reply to 4013.14
Key of the keyboard "Print Screen" ;)
4013.16 In reply to 4013.15
In MoI, there is also a script to capture the viewport at "Any Resolution".... So if you want a high quality image, like 4000x4000, you can set that and get an image of your model!!!!!!!!!!
Very cool....
Show messages: All  1-5  6-16
