Very sharp corners and fillets
All  1-4  5-9
4000.5 In reply to 4000.1
Hi Jim, I've attached an updated version of your model that has those gaps repaired in it.
I fixed them by deleting these faces here from each side:
And then building a new surface there from the 4 surrounding edges using Network, and then joining those to the main body which then gives a solid with all joined edges - this version can now be filleted:
The above is with a fillet radius of 0.04, tha'ts about as high as you can go before some of the fillets in the narrowest area start to collide into one another.
The sharp corner does get filleted, but the corner patch there is a bit funky and lumpy, it's kind of hard on the filleting mechanism to handle sharp corners very well.
4000.6 In reply to 4000.5
I fooled around with this and came up with that result...
Is there any way to rebuild that corner patch to be tangent with the rest??? ( I think not without network tangent patches )
4000.7 In reply to 4000.6
Hi Burr,
> tangent patches )
I think it is actually tangent to those other surfaces, but it ends up having some bunching together making a kind of a lump in the middle of it.
But no, right now there isn't a good way to rebuild a surface and also make it tangent - that is one of the tools that I want to work on for v3.
One thing you can do though is to switch the fillet option to Shape : G2 Blend instead of the regular circular type fillet, it kind of makes a better shaped corner in that area though, like this:
So if you do get a kind of mutated corner patch you can try switching that Shape option to some other fillet styles and one of those may possibly be better formed.
4000.8 In reply to 4000.7
Ah yes, taht is a better patch than I had.... I was trying to delete it and rebuild it.. didnt think to try a g2 instead. Thanks again.
4000.9
Wow, thanks for looking into this in such detail Michael! I'll give that a try later on.
Show messages: All  1-4  5-9
