Default styles
All  1-7  8-11
3994.8 In reply to 3994.5
Hi ed,
> thanks burrman but how do i create that template
> file, i just open MoI and change the styles i want and
> saved it and then load it as a template file but it didnt work.
When you say "load it as a template file", do you mean you put it in as the setting under Options > General > Template file?
Do you possibly have a typo in the file path or something like that?
Try pushing the little "..." button so that you can use the file picker to find the file to make sure you've got the name correct.
If that's still not working, can you let me know what file name and what folder you're putting it in? Maybe there is some bug that some kind of particular name with certain characters is not working correctly or something like that.
3994.9
Thanks for the replies, i dont know what didnt work before, i used the "..." button in the options-general tab but i tried now and it did work, thanks!
3994.10
Now I know what was the problem, I named the first template file, template.3dm, thats why it didnt work!
3994.11 In reply to 3994.10
Hi ed - you can name your template file template.3dm if you want, but you have to put the entire filename including drive, path, etc... like c:\some folder\template.3dm in the options dialog if you just type the name in directly.
If you just enter in only "template.3dm" as the filename, it won't know what folder to go find it in.
When you use the "..." button it will fill in the entire path for the file you pick though, so it's easiest to use that button for setting it.
Show messages: All  1-7  8-11
