hints
 1-4  5-24  25-32
3963.5 In reply to 3963.4
Hi Mark,
> Hi Michael, can I ask what "overhauling the UI to move
> it to a different toolkit" actually means? In particular
> "different toolkit".
It means moving the UI from being based off of mshtml.dll/jscript.dll, to be based off of WebKit instead.
> Does this mean there may be support for Linux?
Possibly, but I don't expect to get a direct Linux build out of it. What I do hope for is that removing the dependency on the mshtml stack will make MoI function a lot better under WINE.
I'm still not sure if that is going to work or not (it depends on WINE handling some other stuff like translating Direct3D calls well) but some early tests did seem promising.
3963.6 In reply to 3963.5
Another wise choice from you Michael, great news.
Is the next step to move from Direct3D to OpenGL?
3963.7 In reply to 3963.6
Possibly in the future, but I don't expect to do that work for MoI v3.
Part of the WINE library involves a translation layer that converts Direct3D calls by a program into OpenGL calls anyway, and if that works well enough I'd probably stick with that for quite a while.
3963.8 In reply to 3963.7
I see, thanks Michael.
3963.9
dare I ask.... moving to a different UI toolkit, could it make it easier to make Moi a crossplatform app, meaning PC/Mac? (one hopes:))
3963.10 In reply to 3963.9
Hi olio,
> (one hopes:))
Well, it's one step towards that anyway.
The WINE library that I mentioned previously does work on Mac as well as Linux, so that may be a way to have a Mac version without actually doing a complete port of everything.
I still don't know quite yet how it will all work out though.
3963.11
What about the Javascript engine? Will it be V8-based? I'm been looking at using V8 in some projects I'm working on, and I've been seriously impressed by its performance...
- Dave Morrill
3963.12 In reply to 3963.11
Hi Dave,
No, it's using the regular JavaScriptCore engine (nitro) that normally goes with WebKit. But it does have the JIT engine enabled, it's fairly close in performance to V8.
3963.13 In reply to 3963.12
Hi Michael and all,
I'm not sure what you mean by webkit. Although, one I've found is this one at http://webkit.org/ an open source project.
I have used Moi on Linux but I find it generally a lot slower. But having Moi running 'natively' on Linux would be so cool (and useful).
Mark.
3963.14 In reply to 3963.13
Hi Mark,
> source project.
Yup, that's it.
Were you using a virtualization system?
The WINE system is not a virtual machine system, it actually loads and executes application code directly so if it works out it should likely be fast.
3963.15 In reply to 3963.14
Hi Micheal,
No, just wine. I installed directx 9 to get Moi to run properly.
It may run slowly though because my system is P4 478 socketed PC. I'm upgrading soon so I'll let you know how the speed is then.
regards,
Mark.
P.S. I can try a virtualization install of Moi3d if the results would be useful?
3963.16 In reply to 3963.15
Hi Mark,
No, that's ok - I do know that MoI runs ok under virtualization on the Mac already.
3963.17 In reply to 3963.12
Awesome! I've mostly been using node.js (which is built using V8), but I've also been keeping an eye on the Javascript arms race in general, so a nitro powered MoI should be pretty hot as well. It's too bad IE9 wasn't coming out about a year earlier, you might not have needed to go to all this trouble.
With all the raw scripting performance you're going to have in the new version, hopefully you'll be able to expose more functionality to the scripting API as well...
- Dave Morrill
3963.18 In reply to 3963.17
Hi Dave,
Well, IE9 doesn't run on Windows XP, so it would have been hard to make a dependency specifically on that.
Really the main reason why I'm switching over is to make for a more stable platform so that MoI's UI will run on the same engine on every installation, rather than depending on what version of IE is on any one particular Windows installation.
Having an increase in script performance is more of a nice side benefit...
3963.19 In reply to 3963.18
Doh! Forgot about that.
Sure, I get that. That will be a big win.
Well, I'm still hopeful about being able to do more with scripting in MoI, so WebKit/nitro sounds really exciting to me. Looking forward to trying this out sometime...
- Dave Morrill
3963.20 In reply to 3963.19
Hi Dave - also another nice benefit with being based off of a modern version of WebKit is being able to use CSS3 (with some extensions even) for the UI now. This allows for a lot more stuff like gradients and rounded corners, etc... Previously that sort of stuff was done by lots of little images.
3963.21 In reply to 3963.20
Yes, that will be extremely useful. I've been busy stocking up my library with HTML5, CSS3 and Javascript books for a while now (for other projects). The <canvas> element could also prove useful for creating custom UI components as well. I'm really looking forward to getting under the hood of this new MoI version...
- Dave Morrill
3963.22 In reply to 3963.21
Hi Dave, so the only caveat is that I've got a few different chunks of WebKit disabled in order to reduce the size of the installer.
An increase in installer and download size is the major downside to switching over to the engine being included with MoI.
<canvas> does work though, but I have SVG disabled.
3963.23 In reply to 3963.22
Hmm, I wouldn't think that could be more than a few megabytes plus or minus. Even here in the Philippines, that isn't anything to worry about. Downloading modo 501 was around 2 GB, and that didn't take all that long. Well, it's your call, but I for one would vote for providing as much function as possible. I realize you probably won't need all the bells and whistles (like SVG) for the core MoI support, but it sure seems like it opens up lots of 3rd party possibilities if you throw in the kitchen sink :-)
- Dave Morrill
3963.24 In reply to 3963.23
Hi Dave, well a few megabytes to me is significant. Just in general I place quite a bit of value on having a nice lightweight download and installation. It is true that is not valued by a lot of developers anymore but I think that's a shame though.
It seems pretty unlikely that SVG would ever get used for UI - and UI is the thing that WebKit is used for with MoI...
If someone in the future comes up with some good use for SVG for MoI UI, then that could be possible to turn back on later on.
Show messages:  1-4  5-24  25-32
