Moi + Modo workflow question
All  1  2-4
3923.2 In reply to 3923.1
Hi Jacob, someone with more Modo experience may be able to give you some more specific advice, but I'll try to give a bit here.
For sculpting, you may want to get a kind of more evenly diced up mesh result so that there are plenty of vertices to deform. Normally the mesh output has fewer vertices in areas that are flatter and more in areas that are curvy. But if you want to manipulate vertices in some flat area then you'll want more of them.
You can use the "Divide larger than" option at export time from MoI to help dice up everything into smaller polygon pieces. See here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=804.26
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
> P.S. Is there a way to programmatically add points along
> a curve in MoI? I'd like to write a script that would take a
> profile curve, add a bunch of points to them then apply some
> noise to them <...>
Try the Rebuild command for getting a bunch of points along a curve:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
But there is not currently any way for a script to access the individual control points of a curve, so without that it's not really possible to make a script to jiggle them around right now.
3923.3
Your best bet is not to try and sculpt the mesh directly. Create an EXR vector displacement map and sculpt using that. The micro poly displacement at render should take care of the underlying mesh displacement and shouldn't have any trouble if you have an even mesh as Michael suggested. The advantage of using an image is that you could re-import your MoI model (if you make some changes), and reapply the displacement very quickly. However, you need to UV map the mesh before you can use image based sculpting. Vector displacement maps allow not just height data but side to side as well so you can sculpt cavities and overhangs. Modo 501 also has multi res sculpting but the base mesh must be Catmull-Clarke subdivided before you start, so it won't play well with a MOI mesh.
The time consuming bit is UVing the mesh, but if you use the Atlas option with the UV projection tool, it should be good enough and is very quick. If you get problems with seams, you might have to take a different approach.
Here is a quick example. This is a glass bottle modeled in MOI. The first image is with the vector displacement map and the second is without it.
3923.4
Thank you for your tips, this helps a lot!
I'll try to post results soon :-)
Show messages: All  1  2-4
