New Feb-9-2007 beta available now
 1-5  6-25  26-27
392.6 In reply to 392.5
> This will only happen if we purposely assign Moi to be the
> default program to open 3dm's right?
Correct. Currently it does not set anything up for this, you have to set it using right-click and "Open with" or Tools/Folder options/File Types in Windows Explorer.
This just fixes a bug so that if you do set it up it will work, previously it didn't work.
Eventually I do plan on setting up a file association automatically, but not if there is already something registered for .3dm .
> Is there any way you can set it up so that a file saved in Moi will open
> in Moi. And a file written by Rhino will not open in Moi unless we purposely
> choose to?
Hmmm. I don't know of any way to do this short of something that drastically hooks and changes the default Windows behavior.
The way that the Windows shell normally determines which app to open is totally driven off of the file extension alone.
392.7 In reply to 392.6
About that I have a little problem
I wish associate a 3Dm file (created by Moi fev 2007) to Moi of Fev 9 2007
That seems impossible : it stay to version of Jan 2007
If I associate the icone of this file 3dm (created by Moi fev 2007) to another prog (Amapi for example) that work !
If I re modify the associate to Moi of Fev 9 2007 of this same file it stay always to version of Jan 2007!!!
Crappy windows system :( maybe i miss something but...)
Ok ! I have found something :Just rename the Moi janvier in Koi Janv, so the icone don't find it, and then I can associate with Moi Fev :)
But the renamed Koi Jan must stay renamed if then that restart :D :D :D
What jumble for nothing :D
Ps Now your new associate file works fine by clicking on icone :)
EDITED: 9 Feb 2007 by PILOU
392.8 In reply to 392.7
great stuff. thanx a lot michael ;)
392.9
thanks for the new beta. :)
The updated german translation is available on my site.
MfG
sk2k
392.10 In reply to 392.9
Thx for the update Michael.
Updated Dutch translation:
Unzip and put DutchStrings.txt in C:...\MoI beta Feb-9-2007\ui, or wherever your ui folder is.
Kind regards.
JTB wrote:
> So,next big priority is....???
The next big one is a reworking for how some of the more complex and time consuming commands work, such as fillet, chamfer, booleans and shelling. I'm going to try to get these set up so that they can be canceled in mid calculation, and also set things up in such a way to provide for greatly increased stability in these commands.
The result of this work won't really be immediately apparent, since they will appear to work the same on regular simple cases. But an increase in stability in this area will be a pretty big benefit, together these are by far the most unstable area causing the most program crashes right now.
392.12
Nice update ! The new star tool is cool. Used in combination with other tools it permits to create complex curves and shapes very easily. The new option for arc is nice also.
Now, for me the best thing is the : "New setting in mesh dialog that allows "Divide larger than" to also apply to planar faces" and maybe some tweaking you've done in the OBJ export. I can now import some "problematic" models in Modo without problems :-)
Probably the problem was that Modo can not import NGons with "too many" vertices...
Here's an example with the gun by Steph3D...
Really cool !!! ;-)
392.13 In reply to 392.11
Michael,
Still planning to have Illustrator import export before release of V.1 ?
392.14 In reply to 392.12
Hi Bernard, I'm glad you like the new beta!
I don't think that there were any changes that would effect this model - there were some bug fixes but they were for some more unusual situations, with trim curves that are partially collapsed, and for some edges where some control points of the edge were squished together into a single point.
That's possible... I think it's likely that complex concave ngons are the big problem (http://en.wikipedia.org/wiki/Concave_polygon) - those are the ones where it is pretty easy for a triangulation of the ngon to get messed up, unless your program code has handled things quite carefully.
By dicing them up into smaller pieces you also will break up complex concave trims into smaller bits, where it is much more likely that each polygon will just have a corner clipped off of it so that it will be convex. It's harder to mess up the triangulation of a convex polygon because no matter which points you connect on it, you can't make a line that goes outside of the polygon.
But that's a great tip that will likely help other people who want to bring stuff into Modo.
392.15 In reply to 392.13
Yup, still planning on it. I think it will happen pretty close to the end since it is pretty self contained and doesn't effect other commands or much UI.
If you have a few sample Illustrator files for import, can you please zip them up and e-mail them to me at moi@moi3d.com ?
392.16 In reply to 392.15
Which Illustrator version ? I'm asking because for example Amapi can not import AI files if they are saved in a version above Illustrator 3. I've no clue what the differences ares between the various version...
392.17 In reply to 392.16
Well, any version that you wish would work! :)
Actually just a random variety of different versions would be the best.
Adobe's file format documentation only currently goes up to AI 7, I'm not sure if the most recent version is a lot different from this or not but I guess I will find out.
392.18 In reply to 392.11
Well, MoI's stability is very important since there is no autosave feature yet.It is a good choise to fix or improve these commands...
392.19 In reply to 392.12
Cool!!! I just recently nought Modo, and I'm glad to see this new option helped the import issue. I haven't had a chance to try this out myself, the wife is yelling at me to shut off the computer... :(
jonah
392.20
See Michael! Wasn't my request for Moi to subdivide large planar areas a good idea? ;)
392.21 In reply to 392.20
I wouldn't have added it if I didn't think so! :)
392.22 In reply to 392.1
>>Updated background images ... To do this, click and drag on either the image or the corner scaling grip....
I have figured out why it looks so anomalous....the image corner grips should have a rounded corner.... hehe....
Petr
392.23 In reply to 392.22
:) I actually tried that, but it seemed a little less "frame" like than sharp corners there.
392.24 In reply to 392.17
Illustrator 8 would be great.
Thats what I use to import into Artcam.
____________________
Regards,
Ken
http://www.3dcadjewelry.com/
392.25
Good lord! Look what happens when I go away for a while....a new beta :)
Thanks Michael!
Show messages:  1-5  6-25  26-27
