A question about Hide
All  1-5  6-8
3919.6 In reply to 3919.3
Hi David, also if you want to use that Invert selection + Isolate method, it's possible to combine those 2 things together in just one keyboard shortcut.
For that, put the following on a shortcut key:
script:var gd = moi.geometryDatabase; gd.invertSelection(); gd.isolate();
That shortcut key will then work like a kind of "hide with memory". Select an object and use the shortcut key to hide it, and then later on trigger the shortcut key a second time to restore the object to visible again.
3919.7
Michael:
You don´t know what so lucky are MoI´s users!
Definitively, this script is exactly the thing I was looking for! (I must admit that I couldn´t see that all I need was a combination of Invert selection + Isolate but it is easiest)
Thank you, thank you, thank you! :-)
3919.8 In reply to 3919.7
You're welcome David, I'm glad that script will help you!
Show messages: All  1-5  6-8
