A question about Hide
All  1-4  5-8
3919.5 In reply to 3919.3
Hi David, also you asked:
> And I think that if unhide command only unhide the
> previous hidden objects (not all included in no active layers)
> it was better. At least in my case. What do you think?
I don't think that this would work, it would be too easy for some objects to have no way of being shown easily if it worked like you describe.
Here's the kind of situation where it would not work - say you have 3 objects, and you select one of them and hide it. Now after a little bit you select a second object and hide it as well. Now later on you go to show objects - if it worked the way you are describing only one of the hidden objects would be shown and the one hidden before that would not be shown. But what if you wanted that first one to be shown, now there is a problem...
So to keep things simple, when you use the show function (clicking on the Edit>Hide button with nothing selected), it just shows all objects to ensure that you can have a simple way to get everything showing.
But that's also why there are some supplemental functions like Isolate (right-click) or "Show subset" (Ctrl+click) to help do some more selective operations.
3919.6 In reply to 3919.3
Hi David, also if you want to use that Invert selection + Isolate method, it's possible to combine those 2 things together in just one keyboard shortcut.
For that, put the following on a shortcut key:
script:var gd = moi.geometryDatabase; gd.invertSelection(); gd.isolate();
That shortcut key will then work like a kind of "hide with memory". Select an object and use the shortcut key to hide it, and then later on trigger the shortcut key a second time to restore the object to visible again.
3919.7
Michael:
You don´t know what so lucky are MoI´s users!
Definitively, this script is exactly the thing I was looking for! (I must admit that I couldn´t see that all I need was a combination of Invert selection + Isolate but it is easiest)
Thank you, thank you, thank you! :-)
3919.8 In reply to 3919.7
You're welcome David, I'm glad that script will help you!
Show messages: All  1-4  5-8
