| Hi 2kemon,
 > How does the corresponding situation look with MoI?
 It's fairly similar actually, because one nice feature of MoI is that it runs well on modest hardware, for example you can run it on a basic netbook computer and it does not require a huge powerhouse workstation just in order to function.
 However, MoI v2 will take advantage of multiple CPU cores when creating an export mesh to polygon file formats, including creating an SKP file. Previously in v1 that was a pretty slow process.
 There are some other areas where I do want to try and leverage multiple cores as well, in v3 I will be trying to experiment with that some more.
 re: 64-bit version - currently MoI only has a 32-bit version and that probably won't change anytime too soon, since it takes quite a bit of work to maintain multiple versions.
