Doing a Rhino tutorial in MoI and hit a snag.
All  1-4  5-12
3901.5 In reply to 3901.1
Hi Don, yes like Steve mentions above normally you would want to trim 2 things like that with each object cutting the other.
It can be a good idea to do the trimming of things like that all in one go, which is called a "mutual trim". That's where you have some objects being trimmed where each object is both a part being cut up and also acting as a cutting object at the same time.
That looks something like this - if you start with 2 objects that are crossing through each other:
Now select both of these pieces. That will look like this:
Now run the Edit > Trim command. The trim command will see both those selected surfaces and know that those are parts that will be cut. It will then show you a prompt in the upper right area of the window that says this:
So note there that it says that you can select some cutting objects or you can push Done instead to do a mutual trim - you want to do a mutual trim in this case so instead of picking any cutting pieces you just push Done right now (or right click in a viewport which is a shortcut for pushing Done) without selecting anything else and that tells Trim to use each piece as both an object to be trimmed as well as a cutting object.
Then it will slice it up and let you pick which parts you want to discard (you can right-click on this stage instead of selecting anything if you just want to slice it up and have all the pieces). So in this case you would select these 2 fragments here:
Then when you push Done or Right-click to finish that last stage of the Trim command this will be the result:
3901.6
Thanks Michael & Steve.
I haven't had a chance to work through your suggestions yet, but hopefully sometime today I will. I just wanted to say thanks and I will let you know how I make out with it when I can.
3901.7
I had a chance to complete the model so am posting a finished render.
After completion in MoI, I saved to stp format and opened in TurboCAD where I applied materials, including the label, which I made in Photoshop. I then rendered and saved in jpg format.
You have a great product Michael. I am glad that I happened across it and decided to give it a whirl. I am pretty sure I will purchase it when my trial nears completion.
Size: 169.8 KB, Downloaded: 163 times, Dimensions: 959x800px
Size: 67.9 KB, Downloaded: 128 times, Dimensions: 283x606px
3901.8 In reply to 3901.7
Hi Don, it turned out nicely, that's great that you were able to complete it. And thanks, I'm glad that you like MoI!
3901.9
I agree. It turned out great :)
3DKiwi
Homepages: 3dkiwi.co.nz & C4D Cafe
Nice design!
3901.11 In reply to 3901.7
Hi Don,
it´s nice to see you here.
Rudl
PS for all: Don is one of the best teacher for TurboCad.
3901.12
Thanks for the compliments gentlemen.
It is nice to see you here too, Rudl.
Show messages: All  1-4  5-12
