Moi3D to rapid protoype parts
 1-15  16-28
3897.16
Very good tips, thanks!
3897.17 In reply to 3897.5
The white piece is an ABS type of plastic. The grey is the same, but infused with aluminum powder.
HTH
Chris
3897.18 In reply to 3897.5
Less than 10 days from sending the file to receiving my parts. Shapeways is located in THE NETHERLANDS! Better service than a shop down the road.
$10 per piece.
3897.19 In reply to 3897.6
Not much. output as STL with a decent amount of polygons. Just don't go over 100k, or it will give their machine fits. LOL
3897.20 In reply to 3897.18
> $10 per piece.
That's another thing that is amazing about this, that it has become so very inexpensive.
3897.21 In reply to 3897.20
>> $10 per piece.
>- Michael
Michael, the cost of the 3D print machine is such that I am seriously considering the purchase of one. They are now in the $6-10k range depending on the features and detail resolution.
They used to be $100k when they first came out.
Cheers,
Chris
3897.22 In reply to 3897.21
Yeah but at $10 per part from the service you're going to have to make quite a lot of parts before it would be worthwhile monetarily to purchase the whole machine. But a faster turnaround time would definitely be a major benefit.
Maybe what will end up happening is that there will be more local shops that will have a machine so that you just send the model to your local shop and pick it up right away.
3897.23
You could try a RepRap machine.
http://reprap.org/wiki/Main_Page
Obviously, you have to be a bit of a do it yourself guy, but to me, none of it looks hard.
3897.24 In reply to 3897.22
Nice prints!
It's changing in the 3d printing area..
Stl printers for under 1300$, don't know of the output quality though...
http://www.bitsfrombytes.com/content/rapman
It seems to print around 8x8x10 inches
They are selling materials around 37-70$ a kilo
There's also kits like makerbot and reprap as Steve mentioned.
Marc
3897.25 In reply to 3897.24
> Any pointers on making a MoI file for Shapeway?
Michael,
Another thing you'll want to do is keep your model in positive xyz space. Most machines don't like STL to be in the minus direction of any axis.
I certainly can't afford a 3D printer, but I do play around with a CNC router. Many of the same things apply!
Mike...
3897.26 In reply to 3897.18
That $10 isn`t much. I think they print a lot`s of part so they can dump prises so low :)
What is the volume of your part you printed out?
d3
3897.27 In reply to 3897.23
Incredibly LOW resolution. More of a toy for tinkerers than a useful tool at this point. Maybe someday. Prices keep dropping. I fully expect to see state of the art on your desktop for under $5k within 2 years.
C.
3897.28
The RepRap can go to quite fine resolutions but is slow. The problem with printed parts is overhangs. Shapeways quote a minimum feature size of 2mm which is worse than the RepRap.
I think to get really high resolution with overhangs, unsupported melted plastic is not the way to go. Better is the layered powder with sprayed binder method.
EDITED: 9 Dec 2010 by STEVEH
Show messages:  1-15  16-28
