controlling sweep positions
All  1-11  12-17
3893.12
> not a complete alternative because things like objects being imported from a file or something like that
IMO this would be ok cause if something is imported it has to be already modelled in the first place, and changes should be applied there cause the idea is probably to use the imported object a serveral times/places. This also leads to the question of instances. Is it planed to implement instances?
I did read the thread about multi document window. So the arguments was more in regards to gui-usabillity but there's also the point of the modelling workflow. Lets say I have an imported object which I use in several models. At some point I my have to modify it to adapt it to something. So it would be nice if I could open the source of the instance/source-file in a second window and edit it.
> techniques for repairing holes
This helps alot, thanks for the hint.
~ nos
3893.13 In reply to 3893.9
Hi Michael....
Is there any chance to use LEDAS GEOMETRIC SOLVER in the future, of course it will cost MoI higher.
3893.14 In reply to 3893.13
Hi Anis,
I don't really know - I just don't have enough information about it to be able to give you a good answer on that.
For example, how much does it cost to license it?
3893.15 In reply to 3893.12
Hi Nos,
I don't think that's a proper assumption that everybody is only going to use imported objects as instances and not as something like a main object body to just do further work on.
Yes, I do want to have instances at some point.
Pulling up a completely separate window is a pretty complex process for something like that. I'd be more inclined to do something much more simple for things like that, such as temporarily hide the other stuff, let you work on the object that you want to edit right in the same window you are already working in, and then when you are done everything else goes back to its previous state.
3893.16 In reply to 3893.14
Hi Michael...
As long as I know, some autocad clone use LGS, also some CAM vendor.
Regarding cost, looks like they can provide reasonable cost both for developer and end user.
I think you should discuss further with LGS people. We believe you can develop far more robust and good history and or constraint solver, but here you are one man show. So we hope LGS can speed up development of MoI3D.
Thanks...
3893.17
I suspect that LEDAS would be able to offer a better deal than Siemens.
+1 for looking into ledas
Show messages: All  1-11  12-17
