mesh edges not aligned when exporting Closed
 1-6  7-26  27-46  47-66  …  107-123
3869.7 In reply to 3869.5
Cool Steve!
That is an excellent work flow you have there. It looks like a good way to go to get the best of both worlds!
Bill
  More Options
3869.8 In reply to 3869.5
Hi Steve, that's an interesting technique! Although it could be quite difficult to plan all the slices if the objects get much more complex. It seems that if something takes too much slice planning that could end up being the equivalent amount of work as creating the topology in the poly modeler...
Maybe another kind of similar approach could be to use polyline paths and profiles for the initial creation, that could make objects that are already diced up into several small surfaces. I've attached a sample model.
This has curves that look like this but they are actually just polylines instead of smooth curves:
Then when doing a sweep, it generates a result like this:
Then you might use some of the edge splitting tools in your poly modeler for splitting up the top big n-gon pieces.
  More Options
3869.9 In reply to 3869.8
Yes, it does take some planning for more complex shapes, some I do make completely in a poly modeller. Just a case of which is the easiest/best result. Just as long as you realise that I do not cut up the model into all the actual quads, as there is no need for that. As example, this is just showing part of the model posted by Bill, I made 7 vertical cuts then let the mesher divide up the horizontal by angle in the output mesh settings.
Making the model with polyline paths can work, although you do then lose the vertex normal info(that you would get from the curved surfaces), and a need to then resort to smoothing groups.
- Steve
  More Options
3869.10 In reply to 3869.9
Hi Steve - aren't you going to lose the vertex normals anyway if you end up using the mesh as a control cage and apply sub-d smoothing?
Or are you generating quads for some purpose other than for use as a sub-d control cage?
  More Options
3869.11
Hi Michael and Steve,
Wow! some good information here.
Michael, It doesn't appear that the sub-d smoothing messes up the normals.
Here is an image of a MoI object exported to .lwo and loaded into modo.
In modo I made a copy of the object, added a couple loop slices (to maintain
the sharp edges), then applied sub-d smoothing.
Thanks for the wonderful information.
Bill
EDITED: 23 Nov 2010 by BISENBERGER
  More Options
3869.12 In reply to 3869.9
Hi Steve,
Did you use trim to make the cuts?
From your earlier post I assumed you did that in modo, but it looks like the cuts were
actually made in MoI before exporting.
Bill
  More Options
3869.13 In reply to 3869.12
Hi Bill,
Yes, I used "Trim" in MOI on the various surfaces(edit: then joined them back together), then exported the mesh.
- Steve
  More Options
3869.14 In reply to 3869.13
Thanks Steve,
I like your work flow a lot. It is very helpful.
Bill
  More Options
3869.15 In reply to 3869.11
Hi Bill,
Yeah, I don't expect that they would get messed up, just that the original ones probably get discarded and brand new ones created that correspond to the sub-d surface.
In your case there the original hull and sub-d smoothed result are quite close to the same shape so it's hard to tell any difference in normals just by eyeballing it.
  More Options
3869.16 In reply to 3869.8
>>Maybe another kind of similar approach could be to use polyline paths and profiles for the initial creation, that could make objects that are already diced up into several small surfaces. I've attached a sample model.<<
In my original reply, I stated that "can work". I need to expand on that just in case Bill wants to try that method in the future.
First of all, when you created that sweep, you used a single cross section perpendicular to a one sweep rail, which then produces what you posted, however, problems arise when the ends of the surface(s) are not both on the same plane or not perpendicular for the sweep(as in Bills model). I will try to show some simple examples of the problems.
I have copied 2 curved edges from Bills model, then changed them to polylines(divided up by 16), then for simplicity, have added 2 lines at the ends for the cross sections.
Using one of the cross sections on a one rail sweep produces un-even(at top) spaced sections with a over-run at the other end.
If using the 2 cross sections on one rail, then at first glance it looks OK, but if you then check the top edge(zooming into box area)
There are broken edges. I placed a line(in yellow) snapping to the ends of the broken edges just to show it is not a display problem
If one or both of the cross sections are used on both rails, then there can be a problem, as where edges are expected, there may not be as they are smoothed.
- Steve
  More Options
3869.17 In reply to 3869.16
Hi Steve, yeah probably what you are running into there is if you have a high number of lines like that you probably have many of them that are within tolerance of being considered tangent to one another.
Segments that are considered tangent to each other will get kind of glommed together into longer rail pieces. It would probably be better for that rail segment combining stuff to not happen when the segments are lines.
If you had somewhat fewer lines so that they were not within such a close angle of being tangent to one another you might get a more expected result.
If you could post the 3DM model files of your examples I could test them over here and see if tuning up the rail segment combining solves the problem you are showing or not.
  More Options
3869.18 In reply to 3869.17
I just used curves from the model Bill posted, have attached.
(Bills model still in there)
- Steve
  More Options
3869.19 In reply to 3869.16
Hi Steve, also probably 2-rail sweep is just not going to work for this purpose with segmented polyline rails - 2-rail sweep doesn't know how to produce mitered corners, when there is segmentation it's just going to build the equivalent of small sweeps individual sweeps along each pair of rails, I believe that's one of the problems that you were showing.
If you stick with some other tools like 1-rail sweep, lofting (between same # of segments), extrude, revolve, those would probably work better. Actually Network can work as well with the same number of segments on each side, that may give you what you a similar result that you would be thinking of from 2-rail sweep.
The way that 2-rail sweep works, it kind of drags a frame that slides along each of the rails as it moves along them - this surfacing mechanism just does not particularly have a good way to handle sharp creases in the rails other than in special cases like with rails that have the same shape.
  More Options
3869.20 In reply to 3869.18
Hi Steve,
You can get a proper result from these curves by using Loft between these 2 pieces, instead of using 2-rail sweep:
That produces this result:
2-rail sweep just won't work in general for this particular purpose - here's an example with a smaller number of segments to show more clearly what will happen:
  More Options
3869.21 In reply to 3869.19
The one rail sweeping does not work for this example, there are various problems.
Network gives the same result as 2 rail sweep in this example.
Not to worry, I am OK the way I do this already. I just wanted to point out possible problems to Bill.
- Steve
  More Options
3869.22 In reply to 3869.20
>>You can get a proper result from these curves by using Loft between these 2 pieces, instead of using 2-rail sweep:<<
Yes I know, but those (single)end lines where put in place to simplify the example of the sweep. Try using the actual curves from the edges of the model.
What about the broken edges from the one rail sweep using both end lines?(as shown in the pics)
- Steve
  More Options
3869.23 In reply to 3869.21
Hi Steve,
For 1 rail sweep you'll probably want to do it with just 1 profile and a planar rail which will enable mitered corners. That means that you would make something like flared ends by slicing tips off of a more regular initial shape, rather that incorporating the angled end parts directly into the surface construction.
This is the one that I can probably tune up in v3, it's related to that combining together of things that are within a close angular tolerance of being G1. I think I should be able to detect the case that the inputs are made up only of line segments and make sure that the output has the same segmentation in it.
This is the one that if you had a bit fewer segments in the curves where each line was not so close to being tangent to its neighbor, you would not get that combining effect.
  More Options
3869.24 In reply to 3869.22
Well, it looks weird but it's similar to the 2-rail sweep case - if you use a rougher curve you can see that you get a kind of individual sweep piece along each segment.
When you select both end lines, that basically makes the sweep do a type of gradual morph between the first shape and the second shape, as things travel along the sweep.
So that shape morphing combined with the added rotation as it steps from one segment to the next, makes it unlikely that the separately created pieces are going to line up.
Things do line up if your rail segments are tangent where they touch, so if they are pretty close to being tangent, they get pretty close to lining up but not quite.
If you use that same segmented sweep sample file I posted earlier but with just 1 rail used you can see how the sweeps are created on each segment individually:
So you're getting the same kind of thing as that, just with smaller gaps due to the smaller angular difference in that other case.
  More Options
3869.25 In reply to 3869.22
Hi Steve, and then you get that kind of odd "broken edge" look in that case because the generated pieces were close enough within tolerance to get joined together.
The sweeper attempts to join together the different generated surface pieces that are created from segmented rails.
If you measure the distance of the broken looking spots, you should find that they are less than 0.005 units apart, so that allows them to be joined despite having that much of a gap.
That might be another good thing to handle specially if the rail was only made up of lines - the joining step could be disabled for that case since it is really meant to join together the results from G1 segments which do then connect up nicely.
  More Options
3869.26 In reply to 3869.25
I will stick to my original method of trimming the surfaces once the model is finished(or creating in poly program) when I need quad mesh output.
Trying to create the model directly from facets(in MOI) with the limitations and extra work would make it quite difficult, and potentially lead to having tris when having to cut off ends.
- Steve
  More Options
Show messages:  1-6  7-26  27-46  47-66  67-86  …  107-123
