Render MOI Curves in Modo.
All  1-7  8-12
3857.8 In reply to 3857.7
Yeah it sounds like that might be a solution for simple objects, but for what I have in mind it would probably become pretty unwieldy.
So it sonds like the solution right now for stills is to do what PAQ did, and do a render overlay by matching up the MOI viewport with my Modo camera.
For animation it sounds like I am out of luck, unless I can find a .skp importer for modo that will import the poly lines.
Again thanks for all your help.
Andy
3857.9 In reply to 3857.8
Just thought of another solution. I use 3D Max in conjunction with Modo. 3D Max will import several different types of nurbs objects, as well as .skp format. I could then export my camera from Modo to Max, render my curves in Max, and then overlay them in post. I will try it out when I get a chance.
3857.10 In reply to 3857.9
Okay my idea worked. I exported the moi object as an obj and brought that geometry into Modo. Then I deleted everything but the edges and curves, and exported that as an Iges file. I imported that into Max where I then exported them as splines back into Modo. Luckily the scale stayed consistent between all the import and exports and the splines lined up perfectly.
Granted this is a pretty simple object but I have faith that this will work with very complex objects as well. Animated Moi wireframe objects here I come. ;)
Size: 129.9 KB, Downloaded: 184 times, Dimensions: 720x480px
3857.11 In reply to 3857.10
I'm glad you have a workable method Andy, I hope you'll post a link to some of your animations when you make them!
3857.12
Hi Andy,
What format are you using to export spline from 3dsmax to modo ?
Show messages: All  1-7  8-12
