Render MOI Curves in Modo.
All  1-9  10-12
3857.10 In reply to 3857.9
Okay my idea worked. I exported the moi object as an obj and brought that geometry into Modo. Then I deleted everything but the edges and curves, and exported that as an Iges file. I imported that into Max where I then exported them as splines back into Modo. Luckily the scale stayed consistent between all the import and exports and the splines lined up perfectly.
Granted this is a pretty simple object but I have faith that this will work with very complex objects as well. Animated Moi wireframe objects here I come. ;)
Size: 129.9 KB, Downloaded: 183 times, Dimensions: 720x480px
3857.11 In reply to 3857.10
I'm glad you have a workable method Andy, I hope you'll post a link to some of your animations when you make them!
3857.12
Hi Andy,
What format are you using to export spline from 3dsmax to modo ?
Show messages: All  1-9  10-12
