Bolean Div: keep object when named
All  1  2-3
3851.2 In reply to 3851.1
Hi nos, there is no simple checkbox option for that kind of customized behavior in Boolean Difference, but it is possible to modify the Boolean Difference command script to automatically turn on "keep objects" if you have any named cutting objects rather than that coming only strictly from the UI checkbox value.
I've attached a customized command script that does this - copy this one over top of the regular BooleanDifference.js command script file which is under the \commands subfolder inside of MoI's main installation folder. Make sure to exit MoI first before updating the file.
Does that do what you wanted?
3851.3
Yep, works perfectly.
thanks. Nos
Show messages: All  1  2-3
