Alias Sketch
All  1-2  3-6
3848.3 In reply to 3848.1
Hi Ed, one thing that I should mention though is that for the case where you initially created a curve using the "Through points" method in MoI, I do want to set it up so that you can edit those original points and have the curve update. That would be some part of an extended history editing mechanism I think.
3848.4
That would be great!
Skecthbook is not only 2D prog?
So curves must be more easy to manage?
3848.6 In reply to 3848.5
Yes, I believe so.
It depends on the particular technology that is used for the curves. There are several kinds of curve mechanisms that work the same between 2D or 3D curves, but there are also some that are focused on 2D curves only.
It's likely that sketchbook uses NURBS curves though since that is what other parts of the Alias modeling software has used in the past though.
Show messages: All  1-2  3-6
