relative & absolute angles
All  1-7  8-9
3840.8 In reply to 3840.7
Hi nos - you can try the attached modified version of Rotate to see if that helps.
To apply the modified version, copy the attached Rotate.htm file over top of the original version inside of the \commands subfolder inside of MoI's main installation folder. You may want to make a copy of the original one first so you can easily restore it if needed.
The new version will give a negative number readout for angles between 180 and 360 degrees. So for example if you go to what would have previously been an angle that displayed 270 degrees, it will instead show -90 with this modified version.
It won't matter which direction you move the mouse in though, whether you move it clockwise to the 270 degree mark or counter-clockwise to that position it will read -90 in either case.
3840.9
That works great, thanks alot
~nos
Show messages: All  1-7  8-9
