Point from 2 points given distances
 1-16  17-21
3832.17 In reply to 3832.16
> A little trick if you dont make a another shortcut and
> don't want re type the command
> Type one time, copy it then just copy past it for
> the other time ;)
Also if you just want to repeat the last command that was run you can do that by right-clicking in a view port or pushing the Enter key after the command has finished.
> Seems your script works only in the same window
> and not with circles not coplanar ?
Yes, the circles must be coplanar and also intersecting for this command to work properly.
3832.18 In reply to 3832.17
ah yes the right click :)
3832.19 In reply to 3832.15
Works like a charm. Thank you very very much for your effort to make this plug-in.
George
3832.20 In reply to 3832.19
You're welcome George!
Show messages:  1-16  17-21
