export not working
All  1-2  3-4
3819.3 In reply to 3819.2
Thanks Marco,
That made the difference. I wanted to export the whole project, but I see there is a Save As for that.
Bill
3819.4 In reply to 3819.1
Hi Bill yeah "Export" is actually short for "Export selected objects" - it lets you write out just some of the objects instead of everything, based on the selection. If nothing is selected then it will ask you to make a selection, and the prompt for that is in the area where all command prompts go which is in the upper-right area of the main window.
Then like you already saw, if you want to write out everything regardless of selection you can use "Save As" for that.
Show messages: All  1-2  3-4
