export not working
3819.1
Export not working on MoI v2.
I imported a Rhino file to export from MoI. When I select File>Export nothing happens. To make sure it wasn't the Rhino file I selected File>New then made a rectangle and extruded it. I tried to export the resulting box, but again, nothing happened when I selected File>Export.
3819.2 In reply to 3819.1
hi there
did you select any objects for export?
cheers,
marco
Size: 50.2 KB, Downloaded: 44 times, Dimensions: 800x507px
3819.3 In reply to 3819.2
Thanks Marco,
That made the difference. I wanted to export the whole project, but I see there is a Save As for that.
Bill
3819.4 In reply to 3819.1
Hi Bill yeah "Export" is actually short for "Export selected objects" - it lets you write out just some of the objects instead of everything, based on the selection. If nothing is selected then it will ask you to make a selection, and the prompt for that is in the area where all command prompts go which is in the upper-right area of the main window.
Then like you already saw, if you want to write out everything regardless of selection you can use "Save As" for that.
