Optimize 3D models: Atangeo Balancer
 1-6  7-25
3813.7 In reply to 3813.6
I have to say its a really impressif piece of software.
Just did a quick test with Balancer, looks really great.
So I start from a 3DCoat voxel model, 225k polys.
I reduce it to 11k tris, using Modo, 3Dcoat export option and finally Balancer.
Modo
Takes someting like 15sec ... modo produce a lot of high valance vertex in this case, giving many shading glitches.
3DCoat:
The job is pretty nice, reduction take 2 sec or so. However, the triangulation is very unifrom, meaning less triangle where its actually needed (silhouette).
3Dcoat also produce a lot of micro triangle, that can break the shading.
Balancer:
Here s the Balancer result. Its just great from my pov. No tiny triangle, nice triangle balancing on detailled area. Seems that Balancer also care about the vertex normal from hires model, that sounds perfect for nurbs poly reduction too (but I didnèt test it yet).
Finally the process was nearly in real time (less than 1sec).
Just wondering, is the licence locked to a computer, or is it possible to put on a usb key and use it on multiple computer like MoI/Modo ?
EDITED: 3 Dec 2015 by PAQ
3813.8 In reply to 3813.7
Good question regarding the possibility of putting it on a USB stick. The Atangeo forum might be the place to ask, they have always responded quickly to my enquiries.
I've been using Balancer to reduce models from Moi with excellent results. Vertex normals have been handled very nicely on my models and it does a great job of maintaining material boundaries.
Mark
Mark
3813.9
I've been running some tests on high-detail models from Rhino and Sensable's Freeform voxel sculpting program. Test meshes were in the range of 2.5m polys. Balancer handles them quite easily with good results...
3813.10
Hi guys,
Thanks to everyone for very positive feedback.
PaQ,
Thanks a lot for your great comparison and review.
Balancer for Mac is now officially released!
The Windows version has been also updated
with some improvements to visualization and navigation.
And now you can run Balancer for Windows from a USB stick. :)
@PaQ
Have you try Meshlab?
http://meshlab.sourceforge.net/
and Decimation Master inside Zbrush?
http://www.youtube.com/watch?v=xTp6J644zGA
3813.12 In reply to 3813.10
Thanks for the news!
Now that is usable from an USB stick it's very interersting!
I'll buy it for sure.
Are you planning for a combo license Win+Mac?
3813.13
@falcon76
Thanks for asking. We will be glad to give a discount when you buy Win+Mac.
We will check how this can be done with our shopping system.
3813.14 In reply to 3813.13
Hi Atangeo,
Thats great, I'll probably buy a copy at the end of the month :).
I did a quick test versus Zbrush decimation,
http://forums.luxology.com/discussion/topic.aspx?id=40386
(bottom of the page)
For models comming 'outside' zbrush (the modo rhino model in this example), Balancer is much better for the same reasons I posted here : no long micro triangle, no high valance vertex = better shading, especially when you optimize your model at a very low polygon count. Silhouette and shading lools better.
Now the story is different when you decimate a model created in zbrush, maybe decimation master use the subdivision levels info somehow when precomputing the mesh, but for the same polygon count, details are better preserved in zbrush.
But I didnt made tons of test either.
Thanks for the Meshlab link, I'll give a try ... when I have some freetime.
3813.15
Balancer 1.2 is available!
Now you can control face densities for selective reduction rate of
different groups/meshes/sub-meshes. For example, you can set
density of 5 to the head group of your model, to increase the density
of the head vertices roughly 5 times.
See this user guide page here: http://www.atangeo.com/guide/density
Enjoy
EDITED: 20 Jan 2011 by ATANGEO
Size: 123.4 KB, Downloaded: 102 times, Dimensions: 816x546px
3813.16
Hi Guys!
I would like to let you know that Balancer 2.0 released.
Balancer 2.0 features robust and easy to use
accurate pixel-based tolerance simplification.
Now you can easily obtain desired visual quality
just in one click, without thoroughly inspecting
simplified models at different triangle count.
You specify error tolerance in pixels (say 3 pixels)
and your viewport (say 1024 by 1024), and in one click
you get a simplified model, which satisfies your quality
requirement. From any viewing direction, the resulting
model's silhouette won't deviate by more than 3 pixels.
All the rest of new features and improvements we worked on
we also added to Balancer 1.5.1 for those who purchased
Balancer 1.x.
Here is a decimation with 2 pixel error tolerance
for 480 x 480 viewport:
Balancer is available for both Windows and Mac OS X as usual:
http://www.atangeo.com/download
Enjoy!
3813.17 In reply to 3813.15
Hi atangeo
Please correct me if I'm wrong.
I've just started working with MoI (3D modelling) with the intention of modelling some jewellery pieces that I will then get printed at shapways (3D printer)
Shapeways have a limit of 64MB file size and recommend max 1 million polygons.
Would balancer be a good tool for reducing polygons for simple surfaces areas? so I can "save" polygons for high detail areas?
Does anyone here know if Wavefront (.obj) is a good format to use a shapeways, I've been using stl sofar?
Cheers, steve
3813.18 In reply to 3813.17
Hi steve,
I'd recommend using stl format for shapeways - in general stl is the standard format for 3D printing.
Also a binary stl file should probably be a fair amount more compact than an obj file.
Does Atangeo makes some similar thing like Decimation Master ? Better / Less / Similar ?
3813.20
Hi Steve,
Balancer will do a good job by simpifying your model adaptively,
keeping as much details as possible given your required triangle count.
STL is the standard format for 3D printing. Right now, Balancer only supports .obj.
But we will release Balancer nPro just in a couple of weeks. It will have metric-based
tolerance simplification (not only pixel-based), and support of STL format.
Balancer nPro is exactly for simplifying models for 3D printing.
3813.21
Zbrush Decimation master is a good decimation tool,
but Balancer is more robust (no mesh artifacts, skinny triangles etc),
faster, needs much less resources and thus can work easily
with very large models, and can preserve more details given
the same triangle count. Also the latest version of Balancer
has a unique feature to simplify models down to your required
error tolerance. So, basically you get guaranteed visual appearance
without thorough inspection and adjustment of triangle count.
You may take a look at some comparison of
Zbrush Decimation master vs Balancer here:
Here is a comment by a Balancer user on ZBrush:
http://forum.reallusion.com/Topic65513-85-2.aspx#bm105007
3813.22 In reply to 3813.21
Many thanks for the precisions!
Ps And I have seen that was PaQ (a Moi fan) who made the comparaison test ! ;)
3813.23 In reply to 3813.20
Hi atangeo,
Will Balancer nPro do any repair for the models that it simplifies? Like closing holes to make watertight, eliminating non-manifold edges, eliminating intersecting triangles, etc.?
Chris
3813.24
Hi Chris,
Thanks for your question.
The initial release of Balancer nPro will only have watertight verification
in addition to the existing tools in Balancer, vertex joining and T-junction
elimination.
We will gradually add various mesh processing tools like those you mention.
Mesh processing is exactly the area of our expertise. :)
3813.25 In reply to 3813.24
I tried the demo and it is way faster than the ZB Decimation Master!
Nice results and simple interface too.
Show messages:  1-6  7-25
