shortcut assignments
 1-7  8-27  28-29
3808.8 In reply to 3808.7
That is cool, I have a numpad on my laptop...
Peace,
Rich_Art. ;-)
3808.9
Hey, cool, those separate numpad keyboard shortcuts will make a Blender user's life easier in MoI, thanks!
In case you're a Blender user, like me, you might want to check out this thread with Blender keyboard shortcuts for MoI:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6347.1
EDITED: 9 Dec 2013 by SEVENSHEAVEN
3808.10 In reply to 3808.2
Hey guys, it's been a while.
So I came back to moi after a long period of inactivity (I've been modeling in Blender the most lately), to make my actual first commercial 3D model in MoI
I was setting up my V3 non beta last night and I was trying these scripts, and although they do set the view right, the toggle part of the script doesn't seem to be working anymore.
If I understand correctly these are supposed to reverse the view (from top>bottom, left>right etc.) right? Did I do something wrong or did anything change that broke the toggling part of the script?
3808.11 In reply to 3808.10
Hi Duarte, welcome back!
Actually these scripts from the above post (http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2) are meant to just go to one specific view so you can set a specific key to go always immediately to the Back view for example, without needing to do any toggle.
Here are some that will work with a toggle type action, these will set the view to maximized or if already maximized it will toggle it.
Set maximized Top view or toggle Top/Bottom:
script:var vname = 'top'; var vp = moi.ui.mainWindow.viewpanel; if ( vp.mode == vname ) vp.reverseView( vname ); else vp.mode = vname;
Set maximized Front view or toggle Front/Back:
script:var vname = 'front'; var vp = moi.ui.mainWindow.viewpanel; if ( vp.mode == vname ) vp.reverseView( vname ); else vp.mode = vname;
Set maximized Right view or toggle Right/Left:
script:var vname = 'right'; var vp = moi.ui.mainWindow.viewpanel; if ( vp.mode == vname ) vp.reverseView( vname ); else vp.mode = vname;
3808.12 In reply to 3808.11
Oh sorry for the misunderstanding, I was under the impression it was supposed to toggle.
Anyway thanks a lot for those new scripts, they come really in handy. The toggling function really helps a lot, with that option I can really free up a lot of hot keys for other functions,
Many thanks!
3808.13
Friends, hello!
I want to bother you with such a question.
I have a device, quite popular among artists and designers (and it is really very convenient to work with) - TourBox -
with customizable buttons and various knobs, to which you can bind custom hotkeys from almost any program.
I would like to understand - is it possible to bind hotkeys (not in the form of scripts) to this device?
For example, closer-farther, object rotation, change of projection types, various tools?
Perhaps someone has encountered this - I will be grateful for any advice or help.
The device itself (and a description of how to interact with it) is presented on the website
www.tourboxtech.com
3808.14 In reply to 3808.13
As Moi can work with the space Navigator I suppose that will be possible! :)
Wait the answer of Michael !;)
3808.15 In reply to 3808.14
Thank you for your answer!
I also hope that something like this can be done - I just don't know how ))))
3808.16 In reply to 3808.13
Hi krass, it looks like they have instructions here for how to set it up:
https://www.tourboxtech.com/en/manual/how-to-customize-buttons/
You would set up a shortcut key in MOI and then have the device trigger that shortcut key.
3808.17 In reply to 3808.16
Mike, yhanks for answer!
Yes, I have carefully studied these instructions and I have figured out how to assign hotkeys in other applications.
The problem is that MOI3D has a slightly different principle (or I don't understand something) - I can't bind switching projection windows (for example) to some keyboard combination - this or that script is required (which are described at the very beginning of the topic).
And how to implement this - I don't quite understand here (((
3808.18 In reply to 3808.17
Hi krass,
Do you mean you want a shortcut key for the Options dialog > View > "3D view projection" setting?
Go to Options > Shortcut keys and put in this for the "Command" part:
script: var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); if ( vp.projection == 'Perspective' ) { vp.projection = 'Parallel'; } else { vp.projection = 'Perspective'; }
When the shortcut is triggered it will switch the 3D viewport between parallel or perspective projection modes.
There are some of the most commonly used scripts listed here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
like Hide, Lock, reset all views, select all, deselect all, invert selection, go to split view, maximize 3d/top/front/right view, isolate selection, select all curves, turn grid snap on/off, and some more.
Also there are more here:
https://moi3d.com/download/scripts/PetrsMoiPage/PetrsMoiPage.htm
If you want something that isn't listed just post what you want here and I can tell you the script code to do that.
EDITED: 11 Jun 2025 by MICHAEL GIBSON
3808.19 In reply to 3808.18
Apparently I wasn't understood correctly by you.
I wrote that the controller system understands only keyboard shortcuts (and mouse clicks) to program the device.
For example, Alt + F1 (Cntrl + G) and so on.
But not the format of the script type moi (script: var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); if ( vp.projection == 'Perspective' ) { vp.projection = 'Parallel'; } else { vp.projection = 'Perspective'; })
3808.20 In reply to 3808.19
Input just the Moi's short Cut for example "Ctrl + G" defined for a script inside the Moi Options Menu... to a button of TourBox ?
EDITED: 11 Jun 2025 by PILOU
3808.21 In reply to 3808.20
This is an interesting thought, thank you, I will try this method!!
3808.22 In reply to 3808.20
Yes, amazing, it works! )))
Thank you very much
Two points that I would like to clarify.
1 - where can I find a list of all the hotkeys (scripts) for my3d tools?
2 - is it possible to bind the rotation of the selected object to the scroll/dial wheels (now it is done by holding the mouse and rotating it)?
Thank you very much in advance!!
3808.23 In reply to 3808.19
Hi krass, it sounds like you've got it worked out but just in case:
> But not the format of the script type moi (script: var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); <...>
Right, inside MoI you set up the shortcut key and MOI script, like Alt+F1 = script: var vp = moi.ui.mainWindow.etc..
Then inside the device software you don't give the MOI script there, you just tell it to send Alt+F1.
So there are 2 pieces that work together - set up shortcut key with script in MOI and in the device software assign a device button to emit the shortcut key.
3808.24 In reply to 3808.22
Hi krass,
Also there are more scripts here:
Sorry no, the mouse scroll wheel is used in MOI for zooming the view in and out. There isn't any way to set it to do object rotation instead of that.
It is possible to set up a shortcut key that would rotate the selected objects by one step though, would you like that? Scripts that modify objects are set up a little differently than ones that modify settings.
3808.25 In reply to 3808.24
Mike, thank you very much for your (as always very useful and informative) advice.
I will study everything carefully!
As for rotation, it was not about the "mouse wheel", but rather an attempt to tie the rotation of an object/camera (as an option) to the sliders on Turbobox.
There are three different ones and - in addition to rotation, they also have "press" functions.
I am thinking about how they can be used in the work of Moi3D.
EDITED: 12 Jun 2025 by KRASS
Size: 294.3 KB, Downloaded: 141 times, Dimensions: 762x671px
3808.26 In reply to 3808.25
Hi krass, some camera movement for the wheels might be good.
Try some of these:
Rotate 3D viewport one step up:
script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'up', 4.0 );
Rotate 3D viewport one step down:
script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'down', 4.0 );
Rotate 3D viewport one step left:
script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'left', 4.0 );
Rotate 3D viewport one step right:
script: moi.ui.mainWindow.viewpanel.getViewport('3D').rotate( 'right', 4.0 );
Pan active view one step left:
script: var left_right = -1.0, up_down = 0.0, backwards_forwards = 0.0; var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.pan( left_right, up_down, backwards_forwards ); }
Pan active view one step right:
script: var left_right = 1.0, up_down = 0.0, backwards_forwards = 0.0; var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.pan( left_right, up_down, backwards_forwards ); }
Pan active view one step up:
script: var left_right = 0.0, up_down = -1.0, backwards_forwards = 0.0; var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.pan( left_right, up_down, backwards_forwards ); }
Pan active view one step down:
script: var left_right = 0.0, up_down = 1.0, backwards_forwards = 0.0; var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.pan( left_right, up_down, backwards_forwards ); }
Zoom like the mouse scroll wheel forward:
script: var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.wheelZoom( true ); }
Zoom like the mouse scroll wheel backward:
script: var vp = moi.ui.getActiveViewport(); if ( vp ) { vp.wheelZoom( false ); }
3808.27 In reply to 3808.2
RE: VIEWPORT SHORTCUTS
-----on latest V5 beta im currently using testing viewport shortcuts like this (might try toggles later, but this set up i like, logical
and matches the UI as well)...
numpad zero = split
numpad decimal point = 3d
numpad 1 & 4 top / bottom
numpad 2 & 5 front / back
numpad 3 & 5 left / right
I want to have "reset" assigned to numpad+
1. is there a shortcut key which is same as pressing "reset" in the viewport?
UPDATE/NOW SOLVED: used this one:
script:moi.ui.getActiveViewport().reset();
also:
2. can a viewport selection be 'smart' e.g. if object selected and we select "top" it goes to top viewport and "resets"
if object not selected and user clicks or uses shortcut to goto "top" then the object is not "reset" in the view works
as it does now...
Set Top View:
script:var vname = 'Top'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Bottom View:
script:var vname = 'Bottom'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Front View:
script:var vname = 'Front'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Back View:
script:var vname = 'Back'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Right View:
script:var vname = 'Right'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Left View:
script:var vname = 'Left'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Set Split View:
script:moi.ui.mainWindow.viewpanel.mode = 'Split';
Set 3D View:
script:moi.ui.mainWindow.viewpanel.mode = '3D';
EDITED: 4 May by LIGHTWAVE
Show messages:  1-7  8-27  28-29
