Tips for OBJ/LWO export?
 1-6  7-26  27-32
3793.7 In reply to 3793.5
WHen i bring stuff over from another Cad/Cam package i use, even though it was set to "Inches" in the other package, it comes in as "Millimeters" and the object is very huge in the viewport... I first change the model back to inches and it drops back down to size again....
We have discussed this before Michael. Something about the other app (which I believe is working with mm as a native internal unit) that doesnt transfer over properly....
FYI
3793.8 In reply to 3793.7
Hi Burr, I kind of vaguely remember something about that, it was something specific to that one program right?
If you want to make me a sample file (just a box or sphere or whatever), I can take a look at it again just to make sure I'm not missing something on MoI's side with the units setting. Also it would be good to test it with a few other programs and see if they all see the units as being in mm as well or if they see inches...
3793.9 In reply to 3793.8
Hi Michael... Yeah, pretty sure it is the other program.. I opened it in the demo of turbocad and it was mm also..
Here is a stp and an igs file of a default box at 2 inches... I think they are using harmoneyware translators too!
Some interesting observations...
BobCad is more of a cnc toolpathing program than a cad package.. It's viewport is primitive. I think it is more geared towards working with it's ucs system, integrating it with the toolpathing and output stuff..
They have a "part" system and a "default". Default is whats always set, and part is "current document". So you can change all kinds of settings and prefs on the current document, without affecting the next one you open.. It is also allowing opening a file I made, on your computer, and all the system prefs and units and such will change on your computer for that one file, then go back to default for next doc.. It's kindof like if I set a bunch of prefs in MoI.. Background color.. Line colors etc, etc.. Then you open my MoI file and all those background colors and prefs would be set in your MoI...It's kindof shocking and wierd when you open a file from some guy that likes "pink for Solids" lol
WHen I change the unit system in BobCad, the "VIEWPORT AND UCS GRID" change.. The object doesnt change... (In moi, the object is actually changed/scaled)
In BobCad, the units are set to whatever the default system units are set at.. Almost like "no unit specified in the file?"...So I can open either of these as whatever my systems units are set at....
I know... It's kindof odd...
Anyway, thanks for looking...
3793.10 In reply to 3793.9
Hi Burr, thanks for posting the sample files. I tried importing them in a couple of other programs too, like Alibre, Rhino, and ViaCAD, and all give the same results with seeing the file's units as being in mm.
So as best I can tell, that's just something that BobCAD decides to do, it seems to decide to only want to write IGES and STEP files with millimeter units instead of what your current BobCAD units are. Maybe there is an option in there somewhere to tell it to stop doing that and use your current units instead of only mm?
Anyway, it's not actually particularly harmful because like you said it actually preserves the proper size of your object. It wrote out your box with 2 inch sides as a box with 50.8 mm sides, and 2 inches does equal 50.8 mm, so the actual size is still maintained.
Yeah, there is a setting for this so you can decide if you want objects scaled numerically when units change or not so as to maintain the same physically measured size. That's under Options > General > "Unit options" button.
Another way you can do things if you like is to use File > Import to bring the file in, rather than using File > Open.
When you "Open" a file, it means that you are also bringing in some settings from that file like the unit system that it was using.
But when you "Import" a file, it will keep your current settings (and other geometry as well) intact and if the imported file is in different units it will scale it into the current unit system (unless you turn off the option for doing that, it's also under Options > General > "Unit options" button).
So for example if you start up MoI, then set your units to Inches, then do a File > Import of one of your example files there, you will then end up with a 2 inch cube and won't need to alter any units setting since the imported geometry will adapt to your current unit setting rather than the setting being changed.
3793.11 In reply to 3793.10
Hello Michael,
I hope it's ok to jump in this thread. Could you create an option that allow meshing like surfaces are joined? Maybe something like an internal join is done, but the created mesh is without additional "joins". It would be a dream. From time to time I run in the problem, that I mesh an object what needs different materials at different parts of the object. My current workaround is: I joint the object, mesh it and extract the needed mesh parts in Rhino again.
Micha
Visualisation for Designer and Architects | http://www.simulacrum.de
3793.12 In reply to 3793.10
"Import" does indeed bring it in as inches!!! (I would have sworn I tested everything...:o)
Thanks for looking and the help..
3793.13
Hi Michael
>But something that should happen sooner than that is improving the import process by making something like a progress bar so you can see what is going on rather than just having the screen frozen while it is busy working on the import.
It was my request in the french forum. Happy to see that it is in the pipe.
By the way, were do you find time to reply to all of us and continue programming?
Are you alone? Did you receive some request from big companies to buy yours?
3793.14 In reply to 3793.11
Hi Micha,
That would be difficult to do it that way, because joining is a quite intensive process, there is a lot of searching and distance measurement that happens in joining, because you can't just join any 2 naked edges together, you only want to have edges that are close by each other to get joined. That determination involves a lot of calculation.
So that's why joining is a separate process from meshing.
But if I understand what you want, you can use the already existing weld option to do what you need.
You can turn off the welding option to make the generated mesh work like that. The option is here:
When you have a joined object, if you uncheck that "Weld vertices along edges" option, it will still produce a watertight no-crack mesh but the mesh will be clustered into separate non-connected (non-connected in a topological sense, but actually physically touching in location) sets of vertices with one set for each original surface. This will then allow you to use your polygon modeler's mesh processing functions to separate the mesh into individual objects.
In Rhino v1 there was a command called ExplodeMesh which would do this job of breaking a mesh into separate objects, with one object for each connected cluster of vertices. This seems to have been removed in later Rhino versions though, and I'm not sure if there is a replacement for it. The regular Rhino Explode seems like it will do it for meshes that have sharp edges in it (but then making a group out of the pieces??) but not if the pieces are smooth where they are next to one another or something like that.
Yes, that is a major limitation of Rhino that it does not allow you to easily select individual faces out of a joined solid and apply different materials to them.
MoI itself does not have this limitation - you can select faces within a solid in MoI and apply different styles to them, and those will become different material assignments when you export to OBJ format.
EDITED: 30 Sep 2010 by MICHAEL GIBSON
3793.15 In reply to 3793.13
Hi solex,
> of us and continue programming? <....>
Well, it helps that I type fast! :)
But actually answering questions in the forum is an important method for my information gathering which ultimately guides the programming. It helps me to understand what things people are getting confused by and what features in particular would help out the most.
I know it may sound strange, but it can actually even be helpful for programming to go more slowly in some ways. One of the ways that software can get messed up is if it gets a lot of stuff built along a certain direction and then later on with a large body of stuff it is hard to change that direction or change some of the initial assumptions and stuff like that.
3793.16 In reply to 3793.11
Hi Micha, also if you can't find a way in Rhino to break a mesh apart into connected pieces, you can use this utility instead:
http://moi3d.com/download/SeparateOBJ.zip
To use that, export your joined objects from MoI to an OBJ file but make sure to turn the welding option off.
Then run that SeparateOBJ.exe utility on that file, and it will edit the OBJ file to break it into chunks like that.
Then when you load it into Rhino after that, you will have a watertight mesh without cracks but with a separate mesh object for each original surface in the solid.
3793.17
Thanks for all the tips, guys. They've helped me get much cleaner meshes into Lightwave.
However, I'm still having some issues with some of the objects. When pulled into Lightwave Modeler, the object looks generally fine (except for the fact that I get a very large number of flipped polys initially).
When I do a quick, no-frills render though, I get this:
There's all kinds of odd tearing and gapping, but only upon render.
Does anyone have any idea what might be causing this?
3793.18 In reply to 3793.17
Hi jason,
This could mean that you've still got pieces that have not been joined to each other.
What happens if you run the "select naked edges" script that was posted previously in this thread (here: http://moi3d.com/forum/index.php?webtag=MOI&msg=3793.2), do any of the edges highlight? If so then that means those edges are not joined edges between 2 pieces.
Or another way this can happen is if your object is not a completely closed solid - when an object does not define a completely closed sealed volume, it can possibly have polys oriented in either direction, it's only for closed solids that polygons will automatically be oriented to the outside of the object. You can use the Flip command in MoI in cases like this to reverse the positive normal direction for an object that is not a closed solid. But also it can be easiest if you just turn on double-sided rendering so that it doesn't make any difference.
It's a bit hard to see the artifacts clearly, could you zoom in one one area there to show them a bit better? Are they actually holes, or is it a problem with shading?
Shading problems could be from problems with vertex normals or sometimes from self-shadowing artifacts. Do they go away if you turn off shadow rendering?
Could you possibly post (or e-mail to me at moi@moi3d.com) a small part of the model where you've got those artifacts happening so I can examine the geometry?
3793.19 In reply to 3793.17
Hi Jason, also which version of LightWave are you using?
3793.20 In reply to 3793.19
I'm using 9.6, Michael.
I'm away from my machine at the moment, but I will supply you with a little more detail shortly...
3793.21 In reply to 3793.18
Hmm. So in cutting off a piece of geometry for you to sample, I've encountered something very strange:
I selected a piece of the original model, deleted the rest, and did a save as. When I went back to open my original, I now have two instances of almost every face in the object. I have to delete them manually as far as I can tell, although I really hope there's a way to collapse/merge them. In fact, I just reopened the piece I trimmed out and it ALSO has two faces where there should be only one. What could possibly cause that to happen?
Here's a screen shot - the clipping you see is the faces on top of one another:
I've also attached the LWO, the 3DM, and a render of the artifacts I'm getting.
3793.22 In reply to 3793.21
Here's the full original model that's now causing me problems if looking at that one is of any help.
3793.23 In reply to 3793.21
Hi Jason, my guess is that those rendering artifacts are probably a side effect of the surface duplication - when you get polygons stacked up on top of each other like that it can cause rendering problems with the rendering thinking that some of the polygons are shadowing other ones.
Some areas of the model seem to have even more than just 2 pieces stacked up, I just saw one spot that had 4 stacked up pieces.
It's hard to tell at this point if that duplication was in the original IGES file, or if it was some side effect that happened when attempting to join the surface pieces in the original IGES file together. One way you could tell about this part would be to turn off the automatic joining that happens with IGES importing (that's under Options > Import/Export > IGES options > "Join surfaces on import"). If you have that turned off, when you import the file do you get stacked up pieces or no stacked up pieces?
Also I've attached here a tuned up version of your sample piece, where I have removed the duplicate surfaces and have just single surfaces all joined together. Could you please test exporting and rendering this version and see if your render issues are solved with this version? If so then that would definitely pinpoint that it is the duplicates that are causing the rendering artifacts that you are seeing (most likely in relation to raytrace shadow calculations during the rendering, that's probably why you don't see them in the real-time view since its not doing shadows there), and if that's the case I can then help you to clean up the full model.
3793.24 In reply to 3793.23
Nope, still the exact same issue on render. Looks fine in the GL preview, breaks when rendered (albeit in a very slightly different way).
3793.25 In reply to 3793.24
And the bizarre thing about the multiple surfaces issue is that the issue absolutely was not present until I saved the object, closed it, and then re-opened it. I've managed to replicate the problem once or twice, but with absolutely no consistency.
Could there be something wrong with the original IGS file?
3793.26 In reply to 3793.25
Whoa, okay - I figured out the issue with the render artifacts! I swear I tried this very early on in trouble-shooting, but n-gons (well, some of them) were the problem. Simply tripling them worked great.
... but only if I do with triangulation withing Lightwave. If I export from MoI with tris + polys, LW doesn't like it.
I think perhaps the problem is my platform of choice is extremely picky.
Show messages:  1-6  7-26  27-32
