Tips for OBJ/LWO export?
 1-13  14-32
3793.14 In reply to 3793.11
Hi Micha,
> Could you create an option that allow meshing
> like surfaces are joined?
That would be difficult to do it that way, because joining is a quite intensive process, there is a lot of searching and distance measurement that happens in joining, because you can't just join any 2 naked edges together, you only want to have edges that are close by each other to get joined. That determination involves a lot of calculation.
So that's why joining is a separate process from meshing.
But if I understand what you want, you can use the already existing weld option to do what you need.
> Maybe something like an internal join is done, but the
> created mesh is without additional "joins".
You can turn off the welding option to make the generated mesh work like that. The option is here:
When you have a joined object, if you uncheck that "Weld vertices along edges" option, it will still produce a watertight no-crack mesh but the mesh will be clustered into separate non-connected (non-connected in a topological sense, but actually physically touching in location) sets of vertices with one set for each original surface. This will then allow you to use your polygon modeler's mesh processing functions to separate the mesh into individual objects.
In Rhino v1 there was a command called ExplodeMesh which would do this job of breaking a mesh into separate objects, with one object for each connected cluster of vertices. This seems to have been removed in later Rhino versions though, and I'm not sure if there is a replacement for it. The regular Rhino Explode seems like it will do it for meshes that have sharp edges in it (but then making a group out of the pieces??) but not if the pieces are smooth where they are next to one another or something like that.
> It would be a dream. From time to time I run in the
> problem, that I mesh an object what needs different materials
> at different parts of the object.
Yes, that is a major limitation of Rhino that it does not allow you to easily select individual faces out of a joined solid and apply different materials to them.
MoI itself does not have this limitation - you can select faces within a solid in MoI and apply different styles to them, and those will become different material assignments when you export to OBJ format.
EDITED: 30 Sep 2010 by MICHAEL GIBSON
3793.15 In reply to 3793.13
Hi solex,
> By the way, were do you find time to reply to all
> of us and continue programming? <....>
Well, it helps that I type fast! :)
But actually answering questions in the forum is an important method for my information gathering which ultimately guides the programming. It helps me to understand what things people are getting confused by and what features in particular would help out the most.
I know it may sound strange, but it can actually even be helpful for programming to go more slowly in some ways. One of the ways that software can get messed up is if it gets a lot of stuff built along a certain direction and then later on with a large body of stuff it is hard to change that direction or change some of the initial assumptions and stuff like that.
3793.16 In reply to 3793.11
Hi Micha, also if you can't find a way in Rhino to break a mesh apart into connected pieces, you can use this utility instead:
http://moi3d.com/download/SeparateOBJ.zip
To use that, export your joined objects from MoI to an OBJ file but make sure to turn the welding option off.
Then run that SeparateOBJ.exe utility on that file, and it will edit the OBJ file to break it into chunks like that.
Then when you load it into Rhino after that, you will have a watertight mesh without cracks but with a separate mesh object for each original surface in the solid.
3793.17
Thanks for all the tips, guys. They've helped me get much cleaner meshes into Lightwave.
However, I'm still having some issues with some of the objects. When pulled into Lightwave Modeler, the object looks generally fine (except for the fact that I get a very large number of flipped polys initially).
When I do a quick, no-frills render though, I get this:
There's all kinds of odd tearing and gapping, but only upon render.
Does anyone have any idea what might be causing this?
3793.18 In reply to 3793.17
Hi jason,
This could mean that you've still got pieces that have not been joined to each other.
What happens if you run the "select naked edges" script that was posted previously in this thread (here: http://moi3d.com/forum/index.php?webtag=MOI&msg=3793.2), do any of the edges highlight? If so then that means those edges are not joined edges between 2 pieces.
Or another way this can happen is if your object is not a completely closed solid - when an object does not define a completely closed sealed volume, it can possibly have polys oriented in either direction, it's only for closed solids that polygons will automatically be oriented to the outside of the object. You can use the Flip command in MoI in cases like this to reverse the positive normal direction for an object that is not a closed solid. But also it can be easiest if you just turn on double-sided rendering so that it doesn't make any difference.
It's a bit hard to see the artifacts clearly, could you zoom in one one area there to show them a bit better? Are they actually holes, or is it a problem with shading?
Shading problems could be from problems with vertex normals or sometimes from self-shadowing artifacts. Do they go away if you turn off shadow rendering?
Could you possibly post (or e-mail to me at moi@moi3d.com) a small part of the model where you've got those artifacts happening so I can examine the geometry?
3793.19 In reply to 3793.17
Hi Jason, also which version of LightWave are you using?
3793.20 In reply to 3793.19
I'm using 9.6, Michael.
I'm away from my machine at the moment, but I will supply you with a little more detail shortly...
3793.21 In reply to 3793.18
Hmm. So in cutting off a piece of geometry for you to sample, I've encountered something very strange:
I selected a piece of the original model, deleted the rest, and did a save as. When I went back to open my original, I now have two instances of almost every face in the object. I have to delete them manually as far as I can tell, although I really hope there's a way to collapse/merge them. In fact, I just reopened the piece I trimmed out and it ALSO has two faces where there should be only one. What could possibly cause that to happen?
Here's a screen shot - the clipping you see is the faces on top of one another:
I've also attached the LWO, the 3DM, and a render of the artifacts I'm getting.
3793.22 In reply to 3793.21
Here's the full original model that's now causing me problems if looking at that one is of any help.
3793.23 In reply to 3793.21
Hi Jason, my guess is that those rendering artifacts are probably a side effect of the surface duplication - when you get polygons stacked up on top of each other like that it can cause rendering problems with the rendering thinking that some of the polygons are shadowing other ones.
Some areas of the model seem to have even more than just 2 pieces stacked up, I just saw one spot that had 4 stacked up pieces.
It's hard to tell at this point if that duplication was in the original IGES file, or if it was some side effect that happened when attempting to join the surface pieces in the original IGES file together. One way you could tell about this part would be to turn off the automatic joining that happens with IGES importing (that's under Options > Import/Export > IGES options > "Join surfaces on import"). If you have that turned off, when you import the file do you get stacked up pieces or no stacked up pieces?
Also I've attached here a tuned up version of your sample piece, where I have removed the duplicate surfaces and have just single surfaces all joined together. Could you please test exporting and rendering this version and see if your render issues are solved with this version? If so then that would definitely pinpoint that it is the duplicates that are causing the rendering artifacts that you are seeing (most likely in relation to raytrace shadow calculations during the rendering, that's probably why you don't see them in the real-time view since its not doing shadows there), and if that's the case I can then help you to clean up the full model.
3793.24 In reply to 3793.23
Nope, still the exact same issue on render. Looks fine in the GL preview, breaks when rendered (albeit in a very slightly different way).
3793.25 In reply to 3793.24
And the bizarre thing about the multiple surfaces issue is that the issue absolutely was not present until I saved the object, closed it, and then re-opened it. I've managed to replicate the problem once or twice, but with absolutely no consistency.
Could there be something wrong with the original IGS file?
3793.26 In reply to 3793.25
Whoa, okay - I figured out the issue with the render artifacts! I swear I tried this very early on in trouble-shooting, but n-gons (well, some of them) were the problem. Simply tripling them worked great.
... but only if I do with triangulation withing Lightwave. If I export from MoI with tris + polys, LW doesn't like it.
I think perhaps the problem is my platform of choice is extremely picky.
3793.27 In reply to 3793.26
Hi jason - re: n-gons, I have seen LightWave occasionally have problems with certain kinds of n-gons (they have to be triangulated internally in order to be displayed and if something goes wrong with the triangulation, triangles can kind of leak outside of the boundary), but when that happens it should be seen in the realtime view as well.
That's kind of odd to have an n-gon problem that only shows up at render time and not in the regular realtime display...
Maybe the triangulation step that you're doing removes the vertex normal map, and that has more to do with the change in the rendering than the n-gons?
Can you find the vertex normal map listed in some list of maps? Do you get the same kind of result if you delete that and still have n-gons?
At any rate, I have attached here a version of your file that has the duplicated surfaces removed, if that is of any use.
In some areas of the model there are some very tiny slivery pieces, that's probably one of the things causing joining problems with it.
But it sounds from your reply that you have a solution now that works, is that correct?
3793.28 In reply to 3793.27
Yes, I do. I think it was very much a combination of something a little off with the source file and Lightwave being very finicky with n-gons.
Re: the vertex map - it appears to still be applied to my model even after triangulation, because it's very apparent (and messy) if I remove it completely.
Thank you very much for the help.
3793.29 In reply to 3793.28
Hi Jason, well that is pretty mysterious as to why triangulating should make such a big difference, especially if exporting from MoI with "Quads & Triangles" instead of n-gons still has the same kind of issue.
But I'm glad you have a method that works anyway.
3793.30 In reply to 3793.14
"When you have a joined object, if you uncheck that "Weld vertices along edges" option, it will still produce a watertight no-crack mesh but the mesh will be clustered into separate non-connected (non-connected in a topological sense, but actually physically touching in location) sets of vertices with one set for each original surface. This will then allow you to use your polygon modeler's mesh processing functions to separate the mesh into individual objects."
I asked for the "mesh like joined" function, because I don't want to get all surfaces of a polysurface unwelded, only selected one. I need the meshes for a mesh unfolder (UV texture coordinates unfolding). Welded mesh parts are treated as one object and each unwelded connection is treated as cut in the mesh.
Attached an example of a seat cushion. I like to get separate side parts, but the mesh should be generated like from a closed polysurface. It's easier to extract NURBS surfaces than mesh parts. If I would disable the MoI weld function than I would get to much cuts in the mesh.
Micha
Visualisation for Designer and Architects | http://www.simulacrum.de
Size: 178 KB, Downloaded: 60 times, Dimensions: 1275x640px
3793.31 In reply to 3793.30
Hi Micha, I think you'll need to use a polygon mesh modeler for that kind of "just unweld this one particular surface and not other stuff" kind of level of detail on the mesh processing.
It's difficult to include such very specific detailed functions in MoI's mesher, if it did all kinds of special purpose mesh editing functions like that it will end up getting a really complex UI pretty quickly.
Many polygon mesh editing programs should be able to handle what you need - you probably would want to export from MoI with welding turned off, then select the mesh pieces that you want to keep unwelded, invert the selection and then perform a merge vertices / weld type operation on everything else to weld all the other points together where they had multiple vertices stacked in the same location.
Also maybe I have misunderstood what you are asking for - do you want to actually keep the surfaces as separate unjoined surfaces in MoI but still make them mesh as if they were joined? But if so, that's not really feasible to do, the mesher can't make things work like they are joined without actually knowing which things are joined to one another, so there would have to be an additional full joining calculation done at meshing time in order to know that. That joining calculation can be a time consuming operation, so that's something that you need to do to objects before running them through the mesher, it's not something that the mesher can easily handle in addition to meshing.
This is not usually the case if you're using a mesh modeling program.
3793.32 In reply to 3793.31
Thank you Michael. Right, I will ask the developer of the unfolder for more extraction tools.
Show messages:  1-13  14-32
