Honeycomb pattern on dome shape
 1-9  10-29  30-34
3786.10 In reply to 3786.9
Hi eddi,
> or "ObjTo3dm" : http://dave-l.com/grafix/index.php?page=objto3dm
That's probably not going to work since it looks like it creates polygon mesh objects in the 3DM file and not NURBS objects.
MoI only reads NURBS objects from 3DM files and skips over other kinds of object types like spotlights, dimensions, polygon meshes, etc....
3786.11 In reply to 3786.10
Yes, Michael you are right,
it is known, Moi and polygon does not go.
But both tools bring lines from polygons (created in Wings3d) in to Moi.
Both tools offer a different alternative.
Obj23dmWireframe = separate line segments, filesize larger
EDIT:
HE
***ObjTo3dm = closed line segments, filesize smaller, no luck import geometry with polys less than 5 sides
Best alternative for geodome could be Grasshopper, in continuous honeycomb geometry.
http://api.ning.com/files/tNXd3jNkkDzdZmhUQDh7YDdlF2KdESpiSaTFPw8Pu06N5PtTrbnbBpxirrXxEQlj/CUPULOO8.JPG
EDITED: 24 Sep 2010 by EDDI
3786.12 In reply to 3786.11
Hi Eddi,
It sounded like the main goal of that other converter was to make a mesh object in Rhino, but mesh objects in Rhino are limited to 3 or 4 sided polygons.
So it looks like when possible (< 5 sides) that program will convert to mesh objects in the 3DM file.
But that's interesting that it makes a closed polyline for each face that cannot be directly converted into a Rhino mesh object.
3786.13 In reply to 3786.12
Trick in Wings3d,
select edges, use cut(RMB) through 2, export as obj, (colors not correct converted)
In Objto3dm activate under options "convert NURBS to polygons"
Import in moi as closed polylines.
-EDDI
3786.14 In reply to 3786.1
hi jesus here is a way how to do it :
1 : create cylinder and sphere and bloon-union, trim with red line to make just half (surface sim should be where the red line is), shrink surface,
make blue lines where the end controlpoints is .
make green lines lenght =~= half Circumference off cylinder ( yelow curve )=( 3.14 x D) / 2
flaten the surfaces :
move end controllpoints off surfaces to end off green lines
trime with hexsagone pattern
move back the the end controllpoints and you should get good shape
EDITED: 1 Oct 2010 by BLYESS
3786.15 In reply to 3786.14
Amazing trick lyes, thanks to share it !!!!
3786.16 In reply to 3786.14
Very clever technique lyes! well done.
3786.17
Hi all here another trick : make patch with 1 or more cpts in the midel trim with a pattern scale rotate move the midel cpts or extract curves
thank you
Vasarely revival :)
http://www.vasarely.com/
3786.19 In reply to 3786.18
Hi Pilou thanks for the link I didn't know about this artist but I have seen panels like that and I was wondering how is than
I suppose creating curves like this we can call it VASARELY.
3786.20
Thanks Lyes
love the honeycomb pattern solution. Really helpful.
Jamie
@ Lyes
Sure you have made a pure Moi's Vasarely :)
A famous one by Vasarely:)
3786.22 In reply to 3786.21
ouch - that hurt my eyes.
What you see is what you believe - so don't. (from an Amiga500 demo)
3786.23 In reply to 3786.17
Hi Lyes,
I'm not sure if stupid questions are allowed in this forum? :-) but here goes.
How do you make a patch with these extra points?
I've tried adding points to a plane, with no luck.
Kind Regards
Charles
"There are three kinds of people in this world, those that can count, and those that can't"
3786.24 In reply to 3786.23
Just draw the crosshatching lines and run "Network" on them.. The resulting surface will have the point structure of the hatch.
3786.25 In reply to 3786.23
Hi Charles, there's also a "Set Path" option in Extrude that you can use to generate an initial surface with a particular control point count - the surface made with that option will have the same control point structure as the extrusion profile in one direction and the path's control points in the other direction.
See here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1313.2
In the future I do want to make the "Add pt" command be able to add points to surfaces as well but right now it that one only works on curves.
3786.26 In reply to 3786.25
Hi Guys,
Thank you, for the many ways to skin the proverbial cat. I always find it's a great day when I learn something I didn't know the day before. I tried yelling, "Divide", "Divide" at the screen but it didn't seem to work. Maybe in MoI V61.8. An "Add pt" would be most welcome, I agree. I just seems a logical thing to have. However with the simple way yourself and Burrman suggested to create them, it doesn't need to be a priority.
A big thank you, to you both.
Michael, pardon my asking but are you human? The reason I ask is you never seem to sleep. It's almost like you're literally plugged into the system and the minute something hits the forum, you're there like a flash to answer any questions :-)
Kind Regards
Charles
3786.27 In reply to 3786.26
""""""""I tried yelling, "Divide", "Divide" at the screen but it didn't seem to work.""""""""""""""""
Hahahaha! Reminds me of my first experience with a computer. A guy gave me a computer with no OS. Just a blinking cursor. I typed "Hello" and waited for a response??? Called my friend who sent me a basic programmers guide! LOL
3786.28 In reply to 3786.26
Hi Charles, no problem!
Yup, I'm only a human... :) I just check the forum pretty often.
3786.29 In reply to 3786.27
Hey BurrMan,
Oh, yes the good old days. I remember running an amiga version of POVray and watched each of the indivdual pixels take minutes to render. I'd go to bed and guesstimate how many pixels should render by the time I woke up. It never seemed to be enough. After a few weeks I'd finally have an image, and only then did I realise my camera was pointed in the wrong direction.
Charles
Show messages:  1-9  10-29  30-34
