Bisector curve
 1-10  11-30  31-50  51-55
3745.51 In reply to 3745.50
Hey Burr, so your heads up turned out to be pretty spiffy after all... :)
> ALso Michael...I renamed and kept "LineMorph"....:)
Could you please post it here as an attachment in case someone wants that version after all?
3745.52 In reply to 3745.51
:).... LineMorph as originally posted in this thread...Unzip and copy the htm and js file to your commands directory, and then create a shortcut with LineMorph as the command. (Or optionally while in MoI, just hit "TAB" and then type LineMorph)
[EDIT] Updated to add the "Post operation" version also, as talked about in the thread....[EDIT]
3745.53 In reply to 3745.52
LineMorph is the name of the previous BisectorLine name or it's other?
can you put the number of the message of it?
And there is not more the plug that gives exactly this? (length = middle of 2 between Start End lines)
EDITED: 1 Sep 2010 by PILOU
3745.54 In reply to 3745.53
Yes, it's the first version of BisectorLine that I posted, but renamed.
It was the one I posted here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3745.6
That is what LineMorph will do - it will build a new line that has endpoints half-way between the other line's endpoints. Note that this is a different result than half the angle between the 2 lines though.
The newer BisectorLine (posted at http://moi3d.com/forum/index.php?webtag=MOI&msg=3745.41) will create a line at half of the angle between where the extended lines meet.
3745.55 In reply to 3745.54
THX for explanations !
Show messages:  1-10  11-30  31-50  51-55
