Bisector curve
 1  2-21  22-41  42-55
3745.22 In reply to 3745.19
Hi Michael, thanks again and thanks for the explanation.
I don't know, it might be the older CAD thing that I'm accustomed to maybe, it's like that backward hide thing I asked for a little while back, most of the commands are fine it's just some commands feel right when I run the command first then pick the objects.
In NX there's a funny behaviour that's not really documented, I don't think, where each command window has the buttons 'OK', 'Apply' and 'Cancel' after picking whatever you want to do, pressing 'ok' will execute the command and exit the window, picking 'apply' will execute the command and not exit out so you can repeat the command on something else, there is no last command trigger in NX.
The middle mouse button in NX is the OK/Apply button, now the funny thing is if you hit OK in the command window, next time you use that command the middle mouse button is the 'OK' button and the command will exit after the operation, but if you press the 'Apply' button the middle mouse button is now 'apply' for that command and the window stays for another selection, figure the logic in that.
3745.23 In reply to 3745.1
Hi ....
What is the practical usage of Bisector curve ?
3745.24 In reply to 3745.23
Hi Anis,
I use a bisector curve for construction purposes, it's mainly used to make it easier and quicker to get the centreline between two lines which can be at different angles and lengths to each other.
3745.25 In reply to 3745.24
Does the plug works with 2 curves? (not lines )
3745.26 In reply to 3745.24
Hi Danny,
Can you give me screenshot sample usage in your project ?
Thank You :)
3745.27 In reply to 3745.25
"""""""Does the plug works with 2 curves? (not lines )""""""""""""""
No Frenchy. At the moment, if you run it on 2 waving curves, it will just create a staight line, who's start and end points are at the middle point between the 2 curves start and end points.
3745.28 In reply to 3745.27
I dont want to beat ahorse, but had a question here. Perhaps I am misunderstanding something with the bisector. The script is creating a mid to mid point od the 2 lines at whatever length they are. The bisector "should be the ANGLE"??? With my initial method of using a tangent arc and a line with perp snap, bisects the angle. With the script, it is more of a mid 2 mid line generation.
In this file, the red line is MoI's mid to mid, and the other is the angle bisection...
Have I missed something about what was requested or the desired result. Thanks.
3745.29 In reply to 3745.28
Hi Burr,
Yeah probably "bisector" is not the actual right term to use for this.
From what I could tell from what Danny posted at the start of this thread, it sounded like he was currently drawing in construction lines between the endpoints of the lines and then using midpoint snap on those construction lines to get the line that he wanted.
So that's what I automated in this plug-in.
I guess you might call it more like a "line blend" or "line morph" or something like that.
You are correct that doing an extension of the lines until they intersect and then forming a line of half the angle between that intersection (which would more properly be called a bisector I guess) is a different result than what this plug-in is doing.
3745.30 In reply to 3745.28
Hi Burr,
No you haven't, you are correct, thanks for picking this up, a bisector line should be a line that bisects the angle between two lines, I took it for granted that Michael understood what I meant, I should of explained after the bisector line is created the angles between the lines should be equal.
Sorry Michael, with Burr's persistence on this he's pickup that the script doesn't produce a true bisecting line, I haven't used it for anything yet just initial tests to see if the script works, no doubt I would of picked it up once using it.
Is it still possible to get something to produce a line that bisects the angle between two lines.
Cheers and thanks again Burr.
So Plug must be modified or not ? :)
3745.32 In reply to 3745.29
tangent arc's perp.
3745.33 In reply to 3745.30
Hi Danny, sorry - in your first post when you mentioned using construction lines I assumed you were talking about connecting the endpoints with construction lines and then drawing in a new line between the midpoints.
What is the actual process that you were using with construction lines previously?
3745.34 In reply to 3745.30
Also another that got me confused I guess is the discussion about what to do with bendy curves.
If you want a line that is half the angle between the extended lines, I don't think there is actually anything with bendy curves that corresponds with that, is there?
So when you said that would be good to have for bendy curves as well in v3, that kind of confirmed to me that you must be talking about a kind of Illustrator-style "blend" or morph type operation between the curves...
What is it that you would expect to get from the "half angle" bisector method between 2 bendy curves then?
3745.35 In reply to 3745.33
My apologies, here at work when we refer to construction lines we mean any curve used for construction, so that includes circles, arcs and lines, I'll have to remember to converse in MoItalk when posting something in the forum to avoid confusion.
As for bendy curves, it just sounded like a good idea, but to be truthful I don't know where I would use such a function unless it can be used for more artistic 2d stuff.
Hope I didn't take up too much of your time ?
3745.36 In reply to 3745.35
Hi Danny, I see - so yeah I sort of got on the wrong track when you mentioned construction lines, sorry about that.
But I'm not sure that there actually exists a proper equivalent solution with bendy curves.
There could be a solution for bendy curves if we were talking about the kind of "averaging the endpoints" type method though.
Nope, that one was quite easy to do and only took a few minutes. I'll see if I can cook up the proper one for you now though, it will be a bit more involved but should not be too bad.
One question though is how long would you expect for the bisector line to be, should it have one endpoint at where the original lines would intersect when extended? Then how far along it would you want the other endpoint?
3745.37 In reply to 3745.35
Hi Danny, also one other question - what should it generate in cases like the following where the 2 lines already cross or touch one another:
Should it generate 2 bisector lines in situations like those?
And again, how long should the bisector lines be, maybe instead of 2 bisectors for stuff like that, should it make 4 lines that all have one endpoint on the intersection point? Or just 2 longer lines that go through the intersection point?
3745.38 In reply to 3745.36
mmm, good question. It doesn't really matter as long as there is a line bisecting the angle between the two lines, what ever is easier, maybe the average length of the input lines, in NX it starts from the intersection of the two lines and allows you interactively stretch the line to whatever length you want from that point, like a normal draw line function, but that wouldn't be necessary.
I'm not really fussed about the bendy option, as I said it sounded like a good idea at the time, but if anyone else has a use for it by all means.
3745.39 In reply to 3745.37
I would expect this:
Now you've lost me. I'm only expecting one line as in the picture above.
3745.40 In reply to 3745.39
Hi Danny, here's an example of 2 possible bisector lines where there are 2 crossing lines:
Or here's the kind that would be 2 long lines that go through the intersection point, rather than ending at the intersection point:
In order to make 1 line I've got to use some kind of metric to choose between these possibilities, is there some rule that you can describe about which one to choose? Something like "take the direction that has the smallest angle, and go to the side of the intersection that has the largest amount of the lines on it" ?
3745.41 In reply to 3745.39
Hi Danny, so here's a new version which I think will do the proper result that you want, but I guess you may want to do a couple of trial runs and check the output to make sure.
When lines are crossing, it will put the endpoint towards the side that has the greater length of line on it, here are some sample results:
Show messages:  1  2-21  22-41  42-55
