Bisector curve
 1-9  10-29  30-49  50-55
3745.10 In reply to 3745.6
Hi Michael, um try the Repeat tick box and let us know what you get ;)
3745.11 In reply to 3745.10
141 curves!!! :o
Sorry, before load the script
is that result wanted?
3745.13 In reply to 3745.9
Hi Burr,
> tried to be spiffy....Back to plans.
:) I think you were going along that median-line discussion a couple of weeks ago?
3745.14 In reply to 3745.10
Hi Danny,
Well, if 1 bisector is good, a few hundred are 100x as good, right? ;)
This is actually why the repeat tick box is supposed to be disabled for commands that involve selecting objects as their inputs, but I forgot that part.
I've updated the previous attachment, so that it should not show the repeat checkbox anymore for this command.
3745.15 In reply to 3745.12
Yup! And it's possible to get that result by several different methods currently, this is just a way to make it faster if you need to do it many times.
3745.16 In reply to 3745.13
"""""""" I think you were going along that median-line discussion a couple of weeks ago?"""""""
Moreso probably a lack of understanding of the bisector result. :o
3745.17 In reply to 3745.15
ok So I will can add it to my collection ;)
http://moiscript.weebly.com/
In French but Titles' names' scripts are in English :)
3745.18 In reply to 3745.14
What?! I was hoping for the repeat checkbox :( isn't it possible for the command to end and the curves deselected after the bisector curve is created, so another set of curves can be selected ?
3745.19 In reply to 3745.18
Hi Danny, it's not really easy for commands that involve object selection to work with the repeat checkbox, because things are more primarily intended to work by selecting the objects that you want to work on before you run the command.
It's just so ingrained in things like basic file operations in Windows to do "Noun, verb" operations where you pick the thing you are operating on first before triggering the action that works on it...
In MoI I've also tried to accomodate people who are used to picking input objects after a command has been run as well (which is how several older CAD programs are structured), but that post-pick support is kind of a supplementary thing and not really the main focus.
When you work with pre-selection, sometimes you want to do things like do several operations in a row on the same selection, and if every operation removed the selection from the objects that would not be possible...
So when objects are pre-selected doing an immediate repeat does not work very well because it ends up too literally an exact repeat with the same input objects.
But that's one reason why you can right-click to repeat the last command as a separate thing from the repeat checkbox. The way things are set up now, the repeat checkbox is only for drawing commands where you pick points to define objects, and not for commands that involve selection of input objects.
Of course, it could be possible to make a customized version of this particular command that removes selection at the end, it would just behave pretty differently than how other commands are normally structured.
I've attached a version that does this, I think it's more like what you want and it allows for the repeat checkbox to work, but instead this version does not allow the lines to be pre-picked at all, it clears out the selection at the start of the command and clears it at the end of the command, so it behaves differently than the regular way that other MoI commands work.
Maybe I should have something like a "post pick" type global option that you could enable which would do stuff like clear selection like that when running all commands.
3745.20 In reply to 3745.19
< Maybe I should have something like a "post pick" type global option that you could enable which would do stuff like clear selection like that when running all commands.
or by commands? so a board with some cases to enable/disable?
3745.21 In reply to 3745.20
I kind of hope to avoid such messy UIs like huge control panels that have lists of options for every single command...
But that could be a possibility if it comes up often. Maybe instead of a huge list of commands it would be something more like a place where you could list commands that you wanted to behave differently as an exception to the normal behavior.
3745.22 In reply to 3745.19
Hi Michael, thanks again and thanks for the explanation.
I don't know, it might be the older CAD thing that I'm accustomed to maybe, it's like that backward hide thing I asked for a little while back, most of the commands are fine it's just some commands feel right when I run the command first then pick the objects.
In NX there's a funny behaviour that's not really documented, I don't think, where each command window has the buttons 'OK', 'Apply' and 'Cancel' after picking whatever you want to do, pressing 'ok' will execute the command and exit the window, picking 'apply' will execute the command and not exit out so you can repeat the command on something else, there is no last command trigger in NX.
The middle mouse button in NX is the OK/Apply button, now the funny thing is if you hit OK in the command window, next time you use that command the middle mouse button is the 'OK' button and the command will exit after the operation, but if you press the 'Apply' button the middle mouse button is now 'apply' for that command and the window stays for another selection, figure the logic in that.
3745.23 In reply to 3745.1
Hi ....
What is the practical usage of Bisector curve ?
3745.24 In reply to 3745.23
Hi Anis,
I use a bisector curve for construction purposes, it's mainly used to make it easier and quicker to get the centreline between two lines which can be at different angles and lengths to each other.
3745.25 In reply to 3745.24
Does the plug works with 2 curves? (not lines )
3745.26 In reply to 3745.24
Hi Danny,
Can you give me screenshot sample usage in your project ?
Thank You :)
3745.27 In reply to 3745.25
"""""""Does the plug works with 2 curves? (not lines )""""""""""""""
No Frenchy. At the moment, if you run it on 2 waving curves, it will just create a staight line, who's start and end points are at the middle point between the 2 curves start and end points.
3745.28 In reply to 3745.27
I dont want to beat ahorse, but had a question here. Perhaps I am misunderstanding something with the bisector. The script is creating a mid to mid point od the 2 lines at whatever length they are. The bisector "should be the ANGLE"??? With my initial method of using a tangent arc and a line with perp snap, bisects the angle. With the script, it is more of a mid 2 mid line generation.
In this file, the red line is MoI's mid to mid, and the other is the angle bisection...
Have I missed something about what was requested or the desired result. Thanks.
3745.29 In reply to 3745.28
Hi Burr,
Yeah probably "bisector" is not the actual right term to use for this.
From what I could tell from what Danny posted at the start of this thread, it sounded like he was currently drawing in construction lines between the endpoints of the lines and then using midpoint snap on those construction lines to get the line that he wanted.
So that's what I automated in this plug-in.
I guess you might call it more like a "line blend" or "line morph" or something like that.
You are correct that doing an extension of the lines until they intersect and then forming a line of half the angle between that intersection (which would more properly be called a bisector I guess) is a different result than what this plug-in is doing.
Show messages:  1-9  10-29  30-49  50-55
