Gears and sine waves and things
All  1-5  6-7
3730.6 In reply to 3730.5
Hi Keith;
This is another way;
-Draw a circle
-Add a point on the circle and use array circle to copy the points on the circle.
-Copy the circle and points in Z direction.
-Draw wave curve by connecting the points via freeform command (through points).
-extrude the first circle to make cylinder surface.
-use trim to cut the cylinder surface with wave curve.
-use the shell command to give a thickness to surface.
Sharif
Size: 177.8 KB, Downloaded: 118 times, Dimensions: 1920x1040px
3730.7 In reply to 3730.6
Not this picture, but you did say Gears...There's a plugin that will do simple spur gears:
http://kyticka.webzdarma.cz/3d/moi/#SpurGear
Show messages: All  1-5  6-7
