Midpoint snap on curve not working?
All  1-4  5-8
3727.5 In reply to 3727.3
> If you have the "Show edit Frame" enable you will see the
> middle of it for transform resize...
That's the "center of the curve's bounding box", which is different than the "midpoint of the distance as traveled along the curve".
Here's an example of that kind of midpoint:
3727.6 In reply to 3727.5
In my Cad/Cam package, the points tool has some options... "Point on entity by Distance/Percentage." It's very handy.. If you could look into this, I think it could be a great addition to the point command.
3727.7 In reply to 3727.6
Hi Burr, I was kind of thinking in the future that there could be some option for that in an extended properties dialog box for curves...
3727.8 In reply to 3727.5
< That's the "center of the curve's bounding box", which is different than the "midpoint of the distance as traveled along the curve".
yes :)
If for that I that I had rectify "of this box" but as always you will so speedy that you have seen my previous version :)
Show messages: All  1-4  5-8
