Rhino & MoI Render Mesh Problems
All  1-4  5-8
3722.5
In Rhino- when pulling points, the render mesh does not update on the fly. You can force an update using the command RefreshShade. Also you can split creases in Rhino using the command DivideAlongCreases. Then copy/paste to Moi will have no issues...
3722.6 In reply to 3722.4
Hi Danny, yeah that's another way to fix it - because it's a repeating pattern you can just throw out the bad pieces and copy some of the good parts over.
But I just wanted to describe what was going wrong with it - those bad pieces are getting created because of the original surface being a large surface that has internal creases in it, and it seems to be running into a bug in the surface splitter.
3722.7 In reply to 3722.6
OK, understood. Thanks for the clarification
3722.8 In reply to 3722.3
Thanks for those explanations, I'll let my friend know.
regards Colin
Show messages: All  1-4  5-8
