German v2 documentation update
An updated v2 German language translation from Tony Kluever is now available which contains translations of new commands for MoI v2.
The new German command reference can be browsed online here:
http://moi3d.com/2.0/docs/moi_command_reference_German.htm
Also there is a PDF version available for printing here:
http://moi3d.com/2.0/docs/moi_help_German.pdf
And you can also download the command reference to update the help file with the installed version of MoI. To do that download this file:
http://moi3d.com/2.0/docs/v2_German_update.zip
When you unzip it there will be some .htm documentation files which you can copy to your MoI installation to update the installed help files, the readme.txt file tells you which folder to copy them to.
These links are also available on the Resources section of the wiki now.
Thanks very much Tony for your translation!
