Csec and Lineweb
 1-5  6-22
3700.6
This is a great utility Michael. I can't help but think it's sorta related to Network.
Is is worth somehow making this functionality an option for the Network command?
Granted, network generates surfaces, and this generates curves (which I then tend to use for Network at the moment).
Either way, great stuff!
-Will
@ steve - thanks, I'm glad it will be useful!
@ Will - yeah it is kind of related to Network since it involves a gridwork of curves like Network uses. But yeah this command is focused on generating curves (or lines or points) and not a surface like Network is. I'm not really sure how I could combine it with Network without making the command more complex with more options and modes within it.
3700.8 In reply to 3700.7
@BurrMan
--->Stop......My heads going to explode!!! :o
you need doctor ???
-EDDI
3700.9 In reply to 3700.8
Thanks EDDI, I'm ok now. I just needed a moment to wrap my head around how much I like MoI!!!
But when the V3 beta rolls around, i may need serious help.... Do you have any recommendations?
3700.10 In reply to 3700.9
Hey Burr, maybe a a few sessions in Tony's Brain Amplifier would get you ready for V3 :)
3700.11 In reply to 3700.10
"""""""""""Tony's Brain Amplifier"""""""""""
I think he donated that to Michael!!! Thats how he is comming up with that "Only a tool that the developer of the app can think of tool" for the V3 wishlist... :o (Either that or Mrs G is using it for some relaxation after a full day with the little man!!! LOL)
3700.12 In reply to 3700.9
@BurrMan
haha, cool, head back to neck.
--->Do you have any recommendations?
Please ask your physician or pharmacist about the risks and side effects, while using Moi3d.
-EDDI
3700.13 In reply to 3700.2
Hi Michael is it possible to combiend the lineweb command with the loft command ex : type off loft curve or surface
3700.14 In reply to 3700.13
Select all the curves from your LineWeb or Csec, then select Network command. See if that get's you what you are looking for.
Michael T.
Michael Tuttle a.k.a. mictu http://www.coroflot.com/fish317537
3700.15 In reply to 3700.14
hi i have done an icon for it and place it with loft command thank you
3700.16 In reply to 3700.15
Yo CurveMan...Pretty slick. Me likey!
3700.17 In reply to 3700.13
Hi Mario,
Well you can just use Loft directly on the original curves that you selected for LineWeb - it's not necessary to run LineWeb first if you want to loft a surface through a set of curves.
So for example if you have some curves like this:
Select them:
And then run Construct > Loft on them directly:
So note that there isn't any need to run LineWeb if you want to create a loft through those curves.
LineWeb is more for some special effects like if you want to use the curves to build tubes around them or cut them into segments to build panels or things of that nature.
For just creating a surface through the curves you don't really need to be use LineWeb at all, just use Loft by itself.
3700.18 In reply to 3700.17
Hey! This was my request when I asked about "panelling" tool :D Great! Thanks Michael!
3700.19 In reply to 3700.18
Hi all i have done this with lineweb network patch pipe and copy to points started with 3 curves
3700.20 In reply to 3700.19
Hi Mario;
Nice Work!; How did you get the red objects to follow the curve?
Sharif
3700.21 In reply to 3700.20
Hi Sharif i have pulled the control point of the surface up as in the picture
3700.22 In reply to 3700.21
Show messages:  1-5  6-22
