problems selecting curves or lines in V2
All  1-3  4-6
3697.4
I have MoI V2 on Win7 64 running with no problems with selection.
What graphics card/drivers are on the win7 64 system?
3697.5 In reply to 3697.1
Hi michael, this is probably caused by turning on anti-aliasing at the driver level.
MoI uses some calculations using the video card to do some selection stuff, and if the video card forces anti-aliasing to happen during these steps involving selection it can mess things up.
Please go to your video driver settings and see if turning off anti-aliasing there (the setting is often times called "application controlled" or something like that for it not to be forced on) solves the problem or not.
Often times you can have different settings in there for individual programs, and if your driver has that you can set just moi.exe to be "application controlled".
Please let me know if that does not solve the problem or if you have any difficulty locating the anti-aliasing settings in the driver.
3697.6 In reply to 3697.5
thanks for your support.
is has definitely to do with the graphic card settings.
when i switch to per application settings it works fine. (unfortunatly there is no option to save these settings for specific applications)
the graphic card is a ATI Radeon HD 2600 XT and part of a MacPro where i run windows7 on.
the card has also caused some trouble in another 3d app (bonzai3d) and i have yet to find good settings where everything works fine and i have good AA.
maybe it is a macpro related problem. (as their cards might be a little different than the normal pc versions)
EDITED: 28 Jul 2010 by BIGK
Show messages: All  1-3  4-6
