More filleting problems
All  1-4  5-13
3686.5 In reply to 3686.4
But Danny, do you have "Scale on unit system change" selected? under unit options...This would change the behaviour you describe.
3686.6 In reply to 3686.4
Hi Danny,
> I wouldn't expect changing units would effect anything in MoI's
> calculations, if a sphere is 0.06cm in MoI and I change the units
> to mm isn't the sphere still the same size ?
Well, generally algorithms work on just plain numbers...
So for example if you have a sphere that is 20 units in size (whether current units are cm, mm, miles, whatever), that could potentially give a different result than a sphere of 0.0001 units in size even if the units were set to give that some equivalent physical size.
Mostly tolerances are based at some particular fractional value, like 0.001 units regardless of what the current unit system is.
That's pretty much the regular way that CAD programs are set up. Stuff works on numeric values, and a unit system is just a separate tag to mark what those numbers are supposed to be referenced as physically.
But if you try to model a 0.06cm sphere with your units set to Miles, you will be using some really small numbers for your sphere and run into various issues, precision stuff, running close to the tolerance value, etc...
Anyway, I'm able to make this example work by just loading the file and using radius = 0.01, it should not actually be necessary to change the units or scale...
3686.7 In reply to 3686.4
Hi Danny,
> I understand if you model something tiny weeny
But what "tiny weeny" means to the program is if the numeric value are small, like if you are using numbers like radius = 0.0000000001 or things like that.
For example if you have units = Miles, and then have a sphere with radius = 0.00001 miles, that is a nice reasonable size in cm, however it will still be seen from the software's view as being tiny weeny because the numbers being used are tiny.
3686.8 In reply to 3686.6
""""Anyway, I'm able to make this example work by just loading the file and using radius = 0.01, it should not actually be necessary to change the units or scale...""""''''
I originally tried that on my P4 with an old Radeom ati card and it just sat there like the original poster described. Could be this resources issue.
3686.9 In reply to 3686.8
Hi Burr, over here I'm actually using an old P4 and old Radeon card as well, both about 7 years old.
Is this on your machine with the Radeon 7000 in it? That's even beyond old, getting more into "antique" land as far as video card stuff goes... :)
3686.10 In reply to 3686.9
Hahaha. Actually i did get rid of the older 7000 and replaced it with a 2400 hd. Since your last post, I revisited the file. I mispoke.
The only time the fillet doesnt work at that value is picking only a single edge here:
It just sits there. I think I was going around looking for a problem edge and just jumped straight to the scale post I made.
Indeed it fillets at .01 from the original file with a normal selection.
3686.11 In reply to 3686.10
Hi Burr, yeah actually believe it or not filleting just 1 edge like that where it has sharp corners is a lot more difficult than the whole boundary.
It's because the fillet itself won't naturally connect to other fillet pieces, it will want to open up a kind of hole in the model sort of like this:
A couple of different things get difficult there - the fillet does not all by itself cut the top piece, so some additional connections need to be traced on the top to cut the top surface, and then the "side wall" piece has to try to be extended to fill in the gap that is opened up after that.
It's a pretty different kind of scenario than when everything is being filleted - when everything is filleted the fillets and corners all by themselves define a complete trimming boundary.
3686.12 In reply to 3686.11
I had seen that if I selected the "Straight corners" option, then it actually would produce that "Fillet-but-leave-the-original-surface-alone" result, which would allow me to do the lower level surface work if I really needed just that edge filleted... :o
3686.13 In reply to 3686.1
Thanks to Michael, Danny and BurrMan for their help with which I was able to resolve the issues. I have realised that some edges just can't be filleted but I managed to get a useful result nonetheless. Cheers, Dan
Show messages: All  1-4  5-13
