Curve and Points
All  1-9  10-12
3660.10 In reply to 3660.4
Hi Michael;
The second option , save point file, then import point file with control point worked perfectly. this was exactly what I was looking. I also gave a try on "ConnectPoints" script, but it didn't work. no lines showed up between the points. I set the tolerance to 3m which the distance between points.
Thanks again for clear explanation and solution.
Sharif
EDITED: 7 Jul 2010 by SR13765
3660.11 In reply to 3660.10
Hi Sharif,
The method Michael gave is a much better method but, the ConnectPonts script method will work also. The points in the file you posted were measuring at 4.1*** and such, so the value 3 would not produce a result. Try typing 5 and it will do the segments. I then did the join/rebuild and got a curve with no change at "10 points", which is a much less dense curve than the through points curve created with the export point/import point of the original file. If you had many curves like this, it may be good to have this other method available.
3660.12 In reply to 3660.11
Hi BurrMan;
Thanks for clarification. My mistake I had the distance wrong. Yes I tried again and worked fine.
Sharif
Show messages: All  1-9  10-12
