array on path but...
All  1-7  8-13
Message 3658.8 deleted 7 Jul 2010 by BURRMAN
3658.9 In reply to 3658.7
Here's what it looks like when I used your "larger circle" as the size pick for the ArrayGem Command. (I also Arrayed the circle to show how it is sizing it along the path.)
3658.10 In reply to 3658.5
""""""""""Ah yes! of course, the arraygem script, forgot about that one, thanks for picking me up on that Burr."""""""""""""""
Still folding your plans Danny! You focus on the hard stuff.....I'll sweep the corners!!! :o
3658.11
Yes that is what I need.
And this is my WIP...
FiL
___________________
That's a brilliant day!
Size: 312.5 KB, Downloaded: 45 times, Dimensions: 630x507px
3658.12 In reply to 3658.11
Just a note - you may possibly run into problems with ArrayGem if you have a large sized object and a path that has tight bends that make it squiggle around a lot in between where each item should be placed.
The method that is used to converge on a solution can possibly get sort of stuck in one of the squiggles in cases like that.
So for ArrayGem your path curve should try to kind of generally resemble the placement of the items and not have a bunch of extra little wiggles and bends in it that are much tighter than the bounding size.
3658.13 In reply to 3658.12
Normally I use gems like this and paths are softer than this case.
Then the critical points (edges) I work by hand.
But thanks for the note.
FiL
___________________
Show messages: All  1-7  8-13
