Fillet brain freeze
 1-7  8-27  28-47  48-51
3651.28 In reply to 3651.27
Hi Martin,
quote:
The only thing that's still a little puzzeling, is that none of these artefacts seem to show in the Surface Analysis tools that are part of ViaCAD Pro. So does that mean it's just a display 'feature' rather than something fundamentaly wrong with the geometry? I include a couple of Zebra screen shots for reference.
It's most likely an issue with ViaCAD's surface analysis tools - as I mentioned before ViaCAD is just not creating a dense enough mesh to pick up on these ripples which are quite small in size.
But also on top of that zebra stripes by their nature are rather better at displaying how things connect at surface edges where there is actually a break in continuity. It's not so good to detect little ripples that are located within a single surface. Those ripples are actually not continuity breaks, the surfaces have full continuity throughout their interior areas.
It's easy to jump to the conclusion that full continuity also means full quality, but that's unfortunately something that many people are easily mistaken about - you can have full continuity but problems with bumps and lumps.
If you look closely in your zoomed in zebra analysis shot, you can see some of the jagged artifacts that are coming from polygon outlines:
Those polygons are larger than the little bumps, you're not going to be able to see the bumps unless you get polygons that are small enough so that they actually follow the surface more closely.
Even then Zebra is not really the best tool for looking for bumps, glossy specular highlights tend to be better for bump analysis but only if you have a dense enough mesh.
Also as I mentioned, those little bumps are actually related to the reason why the fillet fails in ViaCAD if you go even a little bit larger in radius - the next little bump up in size changes from a kind of awkwardlly bunched area into a full fledged self intersection which is kind of more traumatic.
If you backed off just a slight amount in radius probably those bumps would go away as it would avoid some of the bunching that is causing it.
But I'm pretty sure you've got those bumps in ViaCAD as well (with the radius set to just before it fails), you're just not able to see them because the display mesh is not fine enough even at its "super fine" level.
I've seen the same kind of problem (can't see tiny surface details due to coarse meshing) in other CAD programs as well, it's not particularly unusual. But one of the nice things about MoI's regular display is that it is detailed enough to be able to see those kinds of things.
EDITED: 6 Jul 2010 by MICHAEL GIBSON
3651.29 In reply to 3651.27
Hi Martin, here's another example examining the fillet surface you posted with zebra stripes in Rhino.
If you have a kind of loose density mesh like this for example:
Then it's not too apparent:
Now notice what happens if I up the density by many many times so that the analysis display uses little tiny polygons that hug the surface more closely. With a mesh like this:
The accuracy of the analysis display gets increased and you can see some of those details that were previously getting essentially "blurred out" by a rough mesh:
I don't know if you have any controls available to you in ViaCAD to turn the display mesh up to a really high density as shown above, or to display the outline edges of the display mesh that is currently being used. If you do have controls like that available then crank them up until you see that the generated mesh has very small polygons as in the second example above, and that should help you to see these small surface details. In that example I told Rhino to break down any polygon that was larger than 0.025 units in size.
Also if you're trying to notice bumps using Zebra (which as I mentioned is not really my favorite tool for that job) try to set the zebra stripes to be thinner if possible.
3651.30 In reply to 3651.29
Hello,
Hi armin, and Michael... thanks for your input, I just have no luck with my hardware setup then, I wish I could have some more time to send bug reports etc, maybe I'll give Viacad a third try later this year ... I'll first have a look to the Alibre solution now.
Hi Ralf-S,
This t-flex product seems quite complex for my needs, but thanks for sharing ... I'm really scared by all this historic based modeler, of course I understand all the advantages, but it's not for me ...
I'm really not a tech guy.
During my Viacad tries, I also discover that in some scenario, MoI is giving a better result (as Micahel explains) ... so I end up with a huge waste of time, testing for every fillet scenario, which tool is giving the better result ... maybe also a matter of experience :P ... but very not productive.
3651.31 In reply to 3651.30
Interesting discussion you got here.
I tried this in Spaceclaim with radius 3 and turned the display quality to max (guessing this adjusts the display mesh) and turned on zebra stripes.
Spaceclaim is Acis based, and yes There seems to be a problem with the fillet here too.
It's probably no surprise but Spaceclaim also struggles with radius of 3.
I got the impression this is indeed a real fillet problem, not just a mesh coarsness probelm wen turning the model around.
Michael, I think it's great how you take these things into consideration so the meshing is gives "as accurate as possible" display of the surface.
Your commitment to software quality gives us a better chance to be confident on our model quality!
It's also a pleasure to use Moi because it gives such a direct access to the model.
If anything i would like to see in Moi, - maybe a dynamic sectioning tool for investigating shapes. I think of a kind of "clipping plane + intersection line at the same time" type of thing.
Perhaps also a 2d, flat on screen, curvature graph to se the surface continuity where sections go through two or more joined surfaces.
... just some thoughts
-Fredrik
EDITED: 17 Jul 2010 by FREDRIKW
3651.32
Anybody tried IronCad or SolidEdge with this case?
d3
3651.33 In reply to 3651.32
Yes, if anybody has the chance, would be interesting to see if the Parasolid kernel does it differntly.
Solidworks too uses Parasolid.
-Fredrik
3651.34 In reply to 3651.33
It fillets up to 2.5 but it's also struggling, you can see this colour plot.
Size: 54.7 KB, Downloaded: 55 times, Dimensions: 1334x922px
Message 3651.35 deleted 19 Jul 2010 by KEV_BOY
3651.36
Yes, I'm finding this interesting too. It's an eye-opener that the 'Big Boys'. such as ACIS and Parasolid are both struggling a bit with this one and MoI seems to be taking it in its stride. I assume that as they can't radius this part much beyond 2.4/2.5 they must be hitting some kind of natural limit within the geometry.
If that assumption is correct, then does it mean that MoI's Blend tool is making some subtle changes to other parts of this solid that ACIS and Parasolid wouldn't consider to be acceptable?
I'm not trying to whip up an argument, I'm just wondering why there's a difference.
Martin.
3651.37 In reply to 3651.36
Hi Martin,
To be fair, it's much more common for filleting in ACIS/Parasolid to handle cases that MoI can't, particularly in areas where fillet sections are coming together in a complex corner juncture.
But yes this case does show that the big MCAD kernels are not better in every single case 100% of the time...
Filleting is a really complex area of calculation with a lot of different steps that go into it. The Solids++ kernel has a self-intersection resolution mechanism in it which is what allows it to handle this particular case better.
Yes, that's true - it's due to the tight bend. You can't physically place something that has a large width to it around a bend that is tighter than that width without it causing bunching or self intersection, here's an example:
In this case when the fillet gets over about 2.5 units in size it then runs into this situation where the fillet kind of starts to bunch up and kind of fold over itself in this manner.
That kind of bunching can cause problems in various cases in MoI as well, but in some cases like extrusions it is able to be resolved pretty well.
> acceptable?
MoI's fillet is not modifying anything about the original solid other than the trimming away of some area where the fillet is going.
But it does modify the generated rounded fillet surface - in the area where the regular fillet would not fit here:
It stops the fillet pieces with the exact circular cross-sections outside of that self-intersection zone and instead puts in a different kind of surface blend in that corner which adapts itself to the shape more rather than only having only circular cross sections in that spot.
Both ACIS and Parasolid will put in other similar kinds of non-circular cross section surface blends in other circumstances like for some kinds of corner patches at the ends of edges, they just don't have something that recognizes that the fillet is going to cross over itself at some inside region of the edge like this case.
3651.38
Thanks again for your detailed reply, Michael. It is very much appreciated as I don't as yet even own a licence for MoI!
Martin.
3651.39 In reply to 3651.37
Yes, this is somewhat true but then the big MCAD kernels do offer more options to achieve the desired result, take NX as an example, you can choose from Edge Blend, Face Blend, Soft Blend and Styled Blend (Blend=Fillet), each command tackles fillets differently, then you have finer control also, but you do have to pay 100 times more than what MoI costs.
3651.40 In reply to 3651.39
Hi Danny, does one of those options in NX (Edge blend, Soft blend, etc...) make the fillet for this particular case work at something larger than radius = 2.5 ?
The other part that tends to go along with such things is a decrease in the "ease of use" department - it tends to take a longer learning curve and more dedication of time to learn how to use stuff like that.
Of course if it is central to your job to produce fillets on mechanical parts it can be worth both the money to purchase such tools and the time invested to learn how to work them.
It's not bad to have supplemental tools as well though, geometry comes in such infinite varieties that it's not really possible for there to be 1 single tool that covers every single possible geometric circumstance in the best possible way every single time.
3651.41 In reply to 3651.40
I filleted this in the Parasolids Kernel and it seemd to still bunch up in that area. I had several options, which would section the fillet up in different ways, but they all seemed to produce some curvature irregularities in this area. Some of the available tools here also were to dynamically re-tolerance the solid to have the fillet succeed. For instance, here it re-toleranced to .04 to allow a 4 inch fillet.
Note the additional sectioning done in the surface construction, though the analysis still shows the issue:
This one is "maintain Parabolic curves" in the fillet options
3651.42 In reply to 3651.41
Hi Burr, well that's interesting that it makes that kind of result, it seems that it knows that the fillet would become self intersecting there and attempts to do something else.
The problem is the bunching at the top here:
Fillet surfaces are basically like a loft through a bunch of cross-sections, and surface lofting just does not behave well when one side of the loft is all compressed together like that, it will tend to generate those kinds of little ripples and lumps.
The one in MoI solves this by putting in a blend curve at the top so that there isn't a compressed side like that:
3651.43 In reply to 3651.42
Thats really cool that MoI does something like this well that it seems every other fillet'r has issues with. The result I showed is from Delcams Powershape using the Parasolids kernel, Which is more of a mid range modeler like solid edge or solidworks, though it still gives a bunch of fillet options. I could get it to section up in many different ways, not just that "pole position" result, but they all did the bunching. None did what MoI's does.
Maybe Parasolids needs to see this example to incorporate...LOL
3651.44
I think another possible reason is the lack of topology, the model does not have very many edges and solid modelers really crave ordered topology.
Like how the sides are just two big surfaces is complicating.
3651.45 In reply to 3651.44
Hi Kevin, I'm not sure if a change in topology would make much difference in this case, since it's one smooth shape there is not really any obvious topology changes to make unless you would change the shape to be made of line segments and arcs or something like that rather than 1 smooth curve. But then that would be a different model...
3651.46 In reply to 3651.43
Hi Burr,
I wouldn't be surprised if they would incorporate it at some point actually... It seems that they are recognizing that the regular fillet would self-intersect and at least trying to do something about it.
It actually tends to be better to get a result back even with those little ripples in it rather than nothing at all because then you may be able to do some surgery on it to trim out the bad part and fill it in with something else.
One of the more interesting parts of this is not really so much that MoI's filleter can generate this case better (which is going to be a rather rare occurrence), but rather that you can actually see the little ripples with MoI's regular display rather than having to go to a special analysis mode or possibly not even being able to see it at all in some programs even in analysis modes.
3651.47 In reply to 3651.46
Ah yes. The other program presents to you a fillet that "appears" to be very nice. (Unless analyzed)
I find MoI to be very good at inspecting geometry! (hence my V3 wishlist request for sectioning) It really is powerful in this sense.
Show messages:  1-7  8-27  28-47  48-51
