New Rhino / Cinema 4D Import / Export Plugin announced
All  1-17  18-20
3642.18 In reply to 3642.17
Hi Kreten,
> You said the colors wont export - no problem, but all the
> material that I have in MoI will also be present in Cinema?
Yeah with the default OBJ importer in C4D, the material _assignments_ themselves (the assignment of each polygon face to a particular material slot) do come through, it's the material properties themselves (which for MoI is just diffuse color) which don't. I can't remember if the actual list of materials comes through or not. But for sure the polygon assignments do.
But like I mentioned above, you can fix this problem as well if you use the RipTide plug-in for the C4D OBJ import, which is available for free from here:
http://skinprops.com/riptide.php
If you use the RipTide OBJ importer everything will come through including the materials list and material colors.
3642.19 In reply to 3642.18
I recently switched to cinema 4D and I bought MoI primary for its superb polygone model export. It is really the best tool I have ever seen since starting with 3D Studio 20 years ago.
You will have much fun with Cinema and MoI!
I am just waiting for MoI in 64 Bit to import LARGER CAD files! ;-)
Best regards
BLADE
3642.20 In reply to 3642.19
blade
i think the same about MOI but i am still curious to hear what you think are MOI's main advantages
over those other programs. in particular i would like your opinion on apple for apple basis (basic modelling features)....
whatever is within your knowledge!
thanks
mario
Show messages: All  1-17  18-20
