Hi Kreten,
> You said the colors wont export - no problem, but all the
> material that I have in MoI will also be present in Cinema?
Yeah with the default OBJ importer in C4D, the material _assignments_ themselves (the assignment of each polygon face to a particular material slot) do come through, it's the material properties themselves (which for MoI is just diffuse color) which don't. I can't remember if the actual list of materials comes through or not. But for sure the polygon assignments do.
But like I mentioned above, you can fix this problem as well if you use the RipTide plug-in for the C4D OBJ import, which is available for free from here:
http://skinprops.com/riptide.php
If you use the RipTide OBJ importer everything will come through including the materials list and material colors.
