PDF
All  1-7  8-10
3637.8 In reply to 3637.7
Hi Pilou, I have not really looked that deeply into 3D PDF, it's pretty much a completely separate thing from the regular 2D page-oriented PDF stuff.
It would need completely separate code for trying to read in the 3D PDF stuff, I don't really expect to be able to do that.
Also 3D PDF files are not generally used as a method to transfer 3D data between applications, they are more used for output only to make a file to be displayed in the PDF viewer.
3637.9
Any word on a possible dxf import option? PDF as you say is a bit flakey, would be good to have a robust way to import 2D CAD data.
cheers
3637.10 In reply to 3637.9
Hi Rob, I would like to add DXF import.
But probably DXF export will come first, importers are usually many times more difficult to create than exporters.
Show messages: All  1-7  8-10
