PDF
All  1-3  4-10
3637.4 In reply to 3637.1
I opened your file in illustrator and saved it out as a pdf 5 or 1.4 version and MoI read it in. If I open your original file in notepad, it appears more like binary data where the illustrator one looks like ascii... Yours started with pdf1.3 and the illustrator one started with pdf1.4.
FYI
3637.5 In reply to 3637.4
It also looks like it may have been created on a "Mac OSX" box.
3637.6
Thanks Michael for converting the file for us and thanks Burr for having a look also, some good tips there.
And what about the 3Dpdf format?
http://www.pdf3d.co.uk/pdf3d_overview.php
3637.8 In reply to 3637.7
Hi Pilou, I have not really looked that deeply into 3D PDF, it's pretty much a completely separate thing from the regular 2D page-oriented PDF stuff.
It would need completely separate code for trying to read in the 3D PDF stuff, I don't really expect to be able to do that.
Also 3D PDF files are not generally used as a method to transfer 3D data between applications, they are more used for output only to make a file to be displayed in the PDF viewer.
3637.9
Any word on a possible dxf import option? PDF as you say is a bit flakey, would be good to have a robust way to import 2D CAD data.
cheers
3637.10 In reply to 3637.9
Hi Rob, I would like to add DXF import.
But probably DXF export will come first, importers are usually many times more difficult to create than exporters.
Show messages: All  1-3  4-10
