Circles to DXF
All  1-8  9-19
3635.9 In reply to 3635.1
When I go from MoI to Cut2d, I export MoI linework as AI Illustrator format (untick 'Fit to Page'), then just open the AI in Cut2d.
3635.10 In reply to 3635.9
Thanks for the info Nick.
When I save my MoI curves as .ai and try to open that file in Cut2D, Cut2D says "Failed to import vector data from EPS/AI/PDF file... The file probably contains only bitmap data." Not sure why.
Currently I'm going from MoI to .skp, then into Sketchup, then exporting from SketchUp to .dxf. Cut2D seems pretty happy with that - the imported curves look good.
- Steve
3635.11 In reply to 3635.10
Hi Steve,
It could be possible that Cut2D only reads newer-style AI files which are the same as PDF.
MoI writes the AI v8 type files. With Illustrator v9 and higher there was a big change in the AI file format to become PDF based instead of how it was previously structured.
Some programs only read and write the older style files since they are more simple in structure, but some other programs only read and write the newer style PDF files.
3635.12 In reply to 3635.10
Hey Steve,
I just looked and I have Cut2d v1.1, March 13, 2008. I am using MoI v2 (although I used MoI V1 with no problem also).
Just another thing to try, did you try to 'import' the Ai into Cut2d (instead of opening it). Probably no difference, but what the heck, its worth a shot. ;)
Out of curiosity, what version of Cut2d do you have? I'm not even sure that Vectric has cared to update Cut2d as they would rather spend their efforts on the bigger ticket programs (yes, that was a dig).
-Nick
EDITED: 30 Jun 2010 by BODINI
3635.13 In reply to 3635.12
Thanks for the info Michael and Nick.
Same version here: Cut2D v1.1, March 13, 2008. I tried both the "import" and "open" methods with the same error message.
Fortunately the MoI-to-SketchUp-to-Cut2D trick works well, and is easy to do, so I have a good work-around.
- Steve
3635.14 In reply to 3635.13
huh! weird. i hate it when stuff makes no [apparent] sense like this. attached is the file i made with moi that opens just fine with cut2d. if you have time, try and open it with cut2d and see if it works.
sure your work around works, but you shouldn't have to do it!
-nick
3635.15 In reply to 3635.14
Hi Nick,
Thanks for the file. I get the same error message when I open your file here!
I'm running Windows 7 Home Premium; don't know if that makes a difference.
- Steve
3635.16 In reply to 3635.15
So obviously its a Cut2d problem then. Why am I not surprised? lulz.
i'm going to install it on my windows7 machine and see if it works (currently on xp). vectric's forum is virtually ignored by the management. i do see that win7 is ok for cut2d though, http://www.vectric.com/WebSite/Vectric/support/support_faq.htm
so since this is not a moi problem, perhaps we should move to email or private message? i'll message you my email address.
edit for inquiring minds> it all works fine on my weak version of win7 'starter' on a dell netbook (thats about as lightweight as you can get!). there is something wrong locally on steves system.
-nick
EDITED: 2 Jul 2010 by BODINI
3635.17
Anyway, FYI this is what a successful import of the AI looks like in Cut2d. The blue nodes are points and the green nodes are the bezier control handle thingys (2 per point). Looks like it made 32 of them in a 2" dia circle. I tried with a 20" dia circle and it made 60 points (did Moi decide how many points)?
3635.18 In reply to 3635.17
Hi Nick,
What happens there is a circle is what is called a "rational" curve (that's what gives the R in NURBS), which means in addition to x,y,z values for control points there is also a weight value for each control point as well. These weight values are what allow a NURBS curve to exactly represent conic sections like a circle or ellipse.
The AI format does not have any ability in it to have weight values, it can only contain "non-rational" bezier curves in it.
So if you have a rational curve, when you export to AI format it will get refit into a non-rational spline using a tolerance based refinement mechanism.
3635.19 In reply to 3635.18
Nick and Michael, thanks for looking into this and for the additional info. I'll look into the configuration on my system.
- Steve
Show messages: All  1-8  9-19
