problem with creating a smooth form
All  1-8  9-11
3631.9 In reply to 3631.8
thank you for the hint! i didnt know that i could use fillet between surfaces.. i guess i am on the way now :)
3631.10 In reply to 3631.9
Hi ello, it can be a bit tricky though since you end up with a lot of small pieces that need to be managed and trimmed.
If you can let me know what radius value you wanted the fillet to be, I could give it a try to see if it is going to be feasible or not.
3631.11 In reply to 3631.10
i managed to create it by using a mix of sweep, network (for the rounded edges) and loft. i created curves for all the tricky places. finally i joined all the surfaces and now i have a quite nice surface i can work on with...
cheers,
Ello
Size: 58.2 KB, Downloaded: 47 times, Dimensions: 400x400px
Show messages: All  1-8  9-11
