Hi Max,
> In the View Panel.
I'm kind of unsure about putting what's really a geometry generation tool inside of the View panel.
> It's a section tool. Now I have to use Rhino to make sections out of my models, using
> plugins like the free "Section Tools" or the not-free "VisualARQ".
Please keep in mind that both of those tools have been extensively worked on by developers whose main jobs are just doing those tasks.
> But this is not just an architectural need. I am working for designers as well, and
> they always ask for sections. Plan, section, elevation: it's the design process
There are a couple of different ways you can generate a section line already, you can draw in a line like you've shown there and then use Construct > Curve > Project to project the line onto the object, the result will be a section line:
Another way is to make a plane for where you want the section and then use Construct > Curve > Isect to generate intersection curves between the plane and your object.
